BlendLuxCore Development
Re: BlendLuxCore Development
Playing around with some scenes that contain a lot of imported architectural and other cad elements and it is working flawlessly so far!!
Really awesome
![Smile :)](./images/smilies/icon_e_smile.gif)
DirectDiffuse and IndirectDiffuse passes are completely black, Glossy passes (direct and indirect contain diffuse information).
Is it a bug or a normal/known behaviour?
Sounds like a bug, please make are report on github.
Done.
https://github.com/LuxCoreRender/LuxCore/issues/333
I hope I did it correctly, it's m'y first bug report
do someone know the way to dot texture in luxcore more random and also uniform or make dot smaller.
AFAIK the dot texture has no parameters besides the colors and the mapping, making its usecases very limited.
Don't know exactly what you want, maybe you can do something like this. Note the offsets in the lower 2 mapping nodes. Color to illustrate how it works.
It seems to not quit work as for some reason the dots in a regular texture are not all perfectly aligned. you can see that some of the white dots have red/black corners
Thanks for the reply. Yes this is what i get currently with dot. But my purpose is to use dot texture for flakes layer in a carpaint shader.
![Image](https://cdn.dealerspike.com/imglib/v1/800x600/imglib/Assets/Inventory/D6/96/D6962FF3-67C8-4E48-9F0B-783BEA52D697.jpg)
I know the cycles voronoi cells texture work great.
