File "/home/toni/Blender/blender-2.82a-linux64/2.82/scripts/modules/addon_utils.py", line 351, in enable
mod = __import__(module_name)
File "/home/toni/.config/blender/2.82/scripts/addons/BlendLuxCore/__init__.py", line 23, in <module>
Exception:
Could not import pyluxcore.
ImportError: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.25' not found (required by /home/toni/.config/blender/2.82/scripts/addons/BlendLuxCore/bin/pyluxcore.so)
My System is Linux Mint 18.3 Sylvia 64 Bit, Kernel 4.4.0-150-generic x86_64, Mate 1.18.0
Blender Version is 2.82a
Rebo2000 wrote: ↑Fri Mar 27, 2020 9:24 am
any thoughts ?
The glibc version required by the binaries is not available on your system. I don't know Mint distribution and if you can install the required version otherwise compiling directly from the source may be the only solution.
Exception:
ImportError: libOpenCL.so.1: cannot open shared object file: No such file or directory
No idea what to do.
My system is Linux Mint 19.3 Mate, Graphic is NVidia GTX 1660 Super and the Driver is 440,82
Exception:
No idea what to do.
Your OpenCL installation is likely to be missing or broken. Try to run LuxMark first, if it doesn't work, try to re-install your GPU driver and/or OpenCL ICD.
