Just azure things I guess.
Maybe we should check out the new github actions thing some time.
I merged "for_v2.4" branch with the main branch so, now on, daily/automatic builds will be about v2.4: https://wiki.luxcorerender.org/LuxCoreR ... Notes_v2.4
After the release of v2.3 our automatic build pipelines have stopped triggering.
Needless to say that there was no change, either in the online settings or the yaml scripts...
It should be working again.
According to the docs, there is an implicit default trigger that is released by any change on any branch.
Apparently, it stopped working some days ago and at the moment it must be set explicitly.
Please can the latest stable build for the blender 2.79?
here's BlendLuxCore 2.2 - the lastest for 2.79... https://github.com/LuxCoreRender/BlendL ... xcore_v2.2 (ones w/o 2.80 in the name)
- Odilkhan Yakubov
Are you meant we can test OptixDenoising now?
Optix denoiser is not activated in the addon.
- MetinSeven
- Contact:
I've just installed the first 2.5 build. A few questions:
The BlendLuxCore Preferences and the viewport render kernel precalculations only show CUDA, no OptiX. Is OptiX being used yet?
OptiX denoising is only available for the viewport. Will it also be available for the final rendering soon?
Thanks!
Thanks!
