Indeed.
Build succeeded.
Thank you.
c:\luxcorerender\windowscompile\build_cmake\luxcore\src\slg\sampleresult_types.cl(39): error C4430: missing ty
pe specifier - int assumed. Note: C++ does not support default-int (compiling source file C:\luxcorerender\LuxCo
re\src\slg\rendersession.cpp) [C:\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\slg\slg-core.vcxproj]
c:\luxcorerender\windowscompile\build_cmake\luxcore\src\slg\sampleresult_types.cl(41): error C3646: 'objectID'
: unknown override specifier (compiling source file C:\luxcorerender\LuxCore\src\slg\rendersession.cpp) [C:\luxc
c:\luxcorerender\windowscompile\build_cmake\luxcore\src\slg\sampleresult_types.cl(41): error C4430: missing ty
0 Warning(s)
714 Error(s)
Time Elapsed 00:00:38.26
--- FATAL ERROR RUNNING CMAKE ---
I should have fixed this probelm.kintuX wrote: ↑Wed Jan 22, 2020 2:17 pm Latest commits again break the windows cmake build:
(ending of console output)Code: Select all
... ... ... c:\luxcorerender\windowscompile\build_cmake\luxcore\src\slg\sampleresult_types.cl(39): error C4430: missing ty pe specifier - int assumed. Note: C++ does not support default-int (compiling source file C:\luxcorerender\LuxCo re\src\slg\rendersession.cpp) [C:\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\slg\slg-core.vcxproj] c:\luxcorerender\windowscompile\build_cmake\luxcore\src\slg\sampleresult_types.cl(41): error C3646: 'objectID' : unknown override specifier (compiling source file C:\luxcorerender\LuxCore\src\slg\rendersession.cpp) [C:\luxc orerender\WindowsCompile\Build_CMake\LuxCore\src\slg\slg-core.vcxproj] c:\luxcorerender\windowscompile\build_cmake\luxcore\src\slg\sampleresult_types.cl(41): error C4430: missing ty pe specifier - int assumed. Note: C++ does not support default-int (compiling source file C:\luxcorerender\LuxCo re\src\slg\rendersession.cpp) [C:\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\slg\slg-core.vcxproj] 0 Warning(s) 714 Error(s) Time Elapsed 00:00:38.26 --- FATAL ERROR RUNNING CMAKE ---
