Falloff?
Racleborg
Falloff?
Post by Racleborg » Sat Feb 01, 2020 1:21 pm
Hi All
Is this how to create a type of falloff :?: (attached)
Thanks
Luximage
Re: Falloff?
Post by Luximage » Sun Feb 02, 2020 3:30 pm
Also you can use a combination of these factors with the mix color or the band node.
falloff factors.blend
(577.51 KiB) Downloaded 23 times
Racleborg
Re: Falloff?
Post by Racleborg » Sun Feb 02, 2020 8:40 pm
(577.51 KiB) Downloaded 2 times
Many thanks. This info will be really helpful! :D
SlowHand
Re: Falloff?
Post by SlowHand » Mon Feb 10, 2020 4:37 am
You should calculate dot product between (shading normal vector) and normalized(camera_position - shading position).
I hard-coded the position of a camera.
It would be great if we could get the camera position and calculate a normalized vector from nodes.
Racleborg
Re: Falloff?
Post by Racleborg » Tue Feb 11, 2020 6:59 pm
Hi SlowHand
I will create the setup and play around with it quite a bit to try and get an understanding of what the nodes are actually doing. I'm a bit out of my depth at the moment. :oops:
Many thanks :D
PetrT
Re: Falloff?
Post by PetrT » Wed Feb 12, 2020 7:31 am
Falloff become more close to Luxcore ;)
Yes it must be faced to camera always and camera position is needed
