No comment speak from itself :
https://www.youtube.com/watch?v=V8BVTHxc4LM
							When CRT is Better Than LCD
Re: When CRT is Better Than LCD
You should try to move one around ... you will change your mind
My first SiliconGraphics had a 40+Kg CRT monitor ... it was intimidating and required a couple of people to be moved around
Weight is Crazy but recover all the quality from that old tech would be great.Dade wrote: Tue Feb 11, 2020 4:08 pm You should try to move one around ... you will change your mind![]()
My first SiliconGraphics had a 40+Kg CRT monitor ... it was intimidating and required a couple of people to be moved around![]()
I still remember how i carried my first 16kg CRT to home from shop, it was 2km walk
