Luxcore Vs Octane Preparation test
Re: Luxcore Vs Octane Preparation test
Post by Sharlybg » Thu Jan 30, 2020 4:38 pm
Luxcore is always using whatever you input +1 bounce, that's how exporter is set up, Simon pls. Correct me if wrong.
Thanks you for you input. I remenber now this behaviour from Luxcore. This is strange because you can't also set 0 input inside blendluxcore. it will always return 1 as minimum value so you end up with 2 intead of 1. :oops:
Post by B.Y.O.B. » Thu Jan 30, 2020 5:37 pm
lacilaci wrote:
Thu Jan 30, 2020 4:31 pm
Yes, but that's only relevant if you compare speed at 1 bounce across renderers.
The output with 1 and 2 bounces is the same in LuxCore, just that the 2-bounce output uses MIS so you get less noise. This is exactly why this exporter behaviour is in place: to hide the MIS-specific implementation detail of the engine and make the bounces behave like the user would expect.
Post by Sharlybg » Fri Jan 31, 2020 10:08 am
With further test i've the feeling that by using total path deph settings it is possible to bypass the n+1 behaviour.
Octane deph 1
Luxcore deph 1
Luxcore deph 2
Octane deph 2
As you can see Luxcore Deph 2 is different from deph 1. And only Octane deph look similar to luxcore deph 2 (same for deph 1 in both engine )
lacilaci
Post by lacilaci » Fri Jan 31, 2020 10:36 am
Octane deph 1
Luxcore deph 1
Luxcore deph 2
Octane deph 2
are those same time renderings?
Post by Sharlybg » Fri Jan 31, 2020 10:56 am
Not the same time. not also same quality. as you can see octane is clamping light very hard. at the same time you get this :
Octane 11sc Deph 1
Luxcore 11sc Deph 1
lacilaci
Post by lacilaci » Fri Jan 31, 2020 11:04 am
Octane 11sc Deph 1
Luxcore 11sc Deph 1
Interesting. Luxcore always introduces noise even in directly exposed areas, this is beyond me why it happens. How do we get noise even in the outside areas...
I think if luxcore could clamp indirect light separately from direct ligh, we might be able to get closer result... maybe...
Post by B.Y.O.B. » Fri Jan 31, 2020 11:17 am
Yes, because it actually is depth 3 and 2. They are supposed to be different.
The relevant part of the code is here: https://github.com/LuxCoreRender/BlendL ... ig.py#L276
There's also a comment explaining the reasoning.
Post by Sharlybg » Fri Jan 31, 2020 11:19 am
Sure i think the same. And also i remenber Fstorm behave a bit like that with strong Clamping.
Post by Sharlybg » Fri Jan 31, 2020 11:49 am
Ok so i've removed all the incremental value. Story is the same even if luxcore get now a bit darker Octane is even darker and clamped.
Octane deph 1
Luxcore deph 1
marcatore
Post by marcatore » Fri Jan 31, 2020 4:01 pm
it seems a huge difference...the main is obviously the noise.
Yes, also the lighting is different..but if you make a poll and ask "choose from noise and lighting what is the most different from lux and octane", I'm quite sure that 95% reply "noise".
I'm not sure it a just a matter of clamping...if you want to test this...why don't try to find the clamping value to have that kind of noise free on the surface that receive light?
In my opinion, in Lux it seems that we have always difficulties to clean not just the shadowed surfaces but the lighted too.
