(Open)Subdiv and Displacement shapes
Re: (Open)Subdiv and Displacement shapes
Sharlybg wrote: Tue Jan 21, 2020 1:34 pm Please guys what is the correct node tree and file format for Vector displacement ?
Node tree is here: viewtopic.php?f=3&t=1489&start=10#p18641
You can find an example file in the first post of that thread.
Not sure which software is able to generate vector displacement maps.
So i was right in my setting but my result look weird.
Map from here : https://docs.arnoldrenderer.com/downloa ... 000&api=v2
Sharlybg wrote: Tue Jan 21, 2020 3:42 pm So i was right in my setting but my result look weird.
Unfortunately, there isn't a standard for displacement maps and different programs use different +/-X +/-Y +/-Z orders (it is literally a mess). LuxCore supports map channel remapping and it is configured by default to work with Blender displacement maps.
Arnold/Mudbox have a different order than Blender and they require a re-map: https://github.com/LuxCoreRender/LuxCor ... s.cpp#L294
		// Blender standard: R is an offset along
		// the tangent, G along the normal and B along the bitangent.
		// So map.channels = 2 0 1
		// Mudbox standard: map.channels = 0 2 1
I assume BlendLuxCore is not exposing this setting and just using the default (i.e. Blender way) :?:
Ah yes, exposing map.channels is still on my Todo list.
https://github.com/LuxCoreRender/BlendL ... ent.py#L31
I have added support for all map channel permutations to the vector displacement node.
B.Y.O.B. wrote: Sun Jan 26, 2020 3:18 pm
Thanks you matte for this fast update. Really appreciated.
Fox
Post by Fox »
Both displacement types have disconnect from faces, is this normal?
Fox wrote: Tue May 26, 2020 11:01 am Both displacement types have disconnect from faces, is this normal?
Are you sure the original object had connected faces ? It doesn't look like.
Fox
Post by Fox »
Dade wrote: Tue May 26, 2020 2:27 pm Are you sure the original object had connected faces ? It doesn't look like.
It's defalt blender cylinder. I also tested ctrl+t and mesh -> clean up -> merge by distance.
Fox wrote: Tue May 26, 2020 2:54 pm
As far as I remember, BlendLuxCore has to export disconnected faces if the vertices do not share normals, etc.
