Something is off with translucency in OpenCL
HI there.
So I'm trying to create some curtains, this is the material:
CPU Render:
OpenCL Render:
Exact same material, exact same object, exact everything.
@dade @B.Y.O.B. Any ideas of what is happening? something is not working or is broken with OpenCL right now.
CPU Render:
OpenCL Render:
Re: Something is off with translucency in OpenCL
Mixing a solid material (like Disney) with a transparent one (like glossy translucent) can be a recipe for a lot of troubles: does it happen if you use the glossy translucent material alone ?
Yes, it seems the problem is the mix of translucent and disney, there is a difference in brightness when you mix that, I have not tested with velvet or matte, will do.
How can I achieve a translucent curtain feeling without breaking laws of physics? hahaha
Have you tried to use Disney with just some transparency (or opacity, I don't remember how it is called in BlendLuxCore, it is a generic material setting available for all LuxCore materials) ? It would, by far, the fastest solution to render.
It's what I'm doing right now, but it looses the effect of the ligth scattering that make you perceive the window border, but in a blurred/diffuminated way, like in some real curtains, with transparency in the end we get the hard border of the window, so the effect is not the same
Confirmed, Disney + Translucency does somethign weird in OpenCL
OpenCL:
CPU:
Shader:
Blend file:
http://pasteall.org/blend/index.php?id=52783
OpenCL:
CPU:
Shader:
Blend file:
Awesome! Thanks @Dade
