Just a quick update (1st attempt to animate a camera)
We get fibre-optic here tomorrow (at long last!), so hopefully will be able to upload and test larger files.
Link: https://1drv.ms/v/s!AhdwgLaw01tLpwPljJ5 ... A?e=Kcdfd2
A baking test scene
Re: A baking test scene
Yep, great stuff!Racleborg wrote: ↑Fri Dec 13, 2019 12:45 pm Just a quick update (1st attempt to animate a camera)
For scenes that fit into VRAM this will be way better than PGI cache.
You could put a glass vase on the mantel and test if it already catches caustics!
Sure, I'll try that (though I haven't really done caustics before) as well as adding an animated reel-to-reel with LEDs. Should be fun!You could put a glass vase on the mantel and test if it already catches caustics!
Hi Dade
There's on object that appears to not being created.
I've tried a few things like re-unwrapping, but to no avail.
The image shows in the Luxcoreui main preview page but it's not saving.
(Screen clip attached)
Thanks
Thanks
Are you using the very latest version ? I fixed a bug like that a couple of days ago.
Check what glTF is capable of: https://sketchfab.com/3d-models/van-gog ... 1a8296b6f9
Switch the camera mode in first person ... it runs at light speed on my tablet
Yes, latest version. I'm re-downloading them just in case and will test again tomorrow.Are you using the very latest version ? I fixed a bug like that a couple of days ago.
Thanks for the link. Yes, very fast here too and I'm on a very slow connection ....until tomorrow when we get fibre here - yippeeee!Check what glTF iscapable of: https://sketchfab.com/3d-models/van-gog ... 1a8296b6f9
It's now working, thanks.Are you using the very latest version ? I fixed a bug like that a couple of days ago.
Having too many versions of Blender (2.8, 2.81, 2.82) may have been the issue.
It also works in VR mode on the fly with my Oculus Rift.Dade wrote: ↑Fri Dec 13, 2019 10:10 pm Check what glTF is capable of: https://sketchfab.com/3d-models/van-gog ... 1a8296b6f9
Cool!It also works in VR mode on the fly with my Oculus Rift
