Compile on MacOS 10.13
Re: Compile on MacOS 10.13
Both .... iwas able to get rid of the error with using jpgv8d now all seems fine
Just uploading a new version build with jpgv8d.
portfolio http://q3de.com/
Links are updated.
http://q3de.com/wp-content/uploads/2019 ... v8_osx.zip
I'm getting an installation error:
Modules Installed (BlendLuxCore) from '/Users/me/Desktop/BlendLuxCore2.3alpha0_jpgv8_osx.zip' into '/Users/me/Library/Application Support/Blender/2.81/scripts/addons'
File "/Applications/Renderer/Blender.app/Contents/Resources/2.81/scripts/modules/addon_utils.py", line 351, in enable
mod = __import__(module_name)
File "/Users/me/Library/Application Support/Blender/2.81/scripts/addons/BlendLuxCore/__init__.py", line 23, in <module>
Exception:
Could not import pyluxcore.
ImportError: dlopen(/Users/me/Library/Application Support/Blender/2.81/scripts/addons/BlendLuxCore/bin/pyluxcore.so, 2): Library not loaded: @loader_path/lib/libtbb.dylib
Referenced from: /Users/me/Library/Application Support/Blender/2.81/scripts/addons/BlendLuxCore/bin/lib/libembree3.3.dylib
Reason: image not found
Oh ... guess i should have checked with the other mac. Looks like @loader_path does not work with subdirs .... fixed ... one sec i'll reupload.
LuxCoreui should work fine. Does it ?
OK fixed .. same link
yep, LuxCore.app works
Great job mate!
Benchmark scene (PathCPU) opens and renders in Blender!
Danish mood was crashing, will test further.
Thanks again for making this possible!
danish mood crahses here as well with ocl CPU enabled
[LuxCore][621.028] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_DL_ILLUMINATE Kernel
[LuxCore][621.028] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_DL_SAMPLE_BSDF Kernel
[LuxCore][621.028] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_GENERATE_NEXT_VERTEX_RAY Kernel
[LuxCore][621.028] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_SPLAT_SAMPLE Kernel
[LuxCore][621.028] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_NEXT_SAMPLE Kernel
[LuxCore][621.028] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_GENERATE_CAMERA_RAY Kernel
[LuxCore][621.028] [PathOCLBaseRenderThread::0] Kernels compilation time: 36ms
[LuxCore][621.040] Starting 8 native render threads
Assertion failed: (!bsdfSample.IsNaN() && !bsdfSample.IsInf() && !bsdfSample.IsNeg()), function RenderEyePath, file /Users/drquader/Documents/GitHub/LuxCore/src/slg/engines/pathtracer.cpp, line 554.
Abort trap: 6
Lol I was just zipping the crashlog but you beat me to it
Benchmark scene renders fine with GT750M OCL.
Also this beauty here works well.
Does it work with opencl GPU enabled ???
OK now it works on the pool scene ... strange.
