But is it in the list of linked libraries (if it is not directly included in OpenImageIO) ?
Compile on MacOS 10.13
Re: Compile on MacOS
freetype is set to find silently .. well see i just compile oiio
portfolio http://q3de.com/
MB Pro i7 2.3Ghz, IrisPro 1.5GB, GTX750m 2GB - BigSur
Xeon X5650@4Ghz, RX 5700 - BigSur , Windows 10, Ubuntu 20.04
oiio compiled fine with all the flags from the "build_deps" script ... finding freetype of course during configure ... now let's seee
This drives me crazy ... another thing missing from oiio looks like dlib ... installed it let's see ..
edit it's libgif
why is it disabled in the build_deps script ?
edit it's libgif
Undefined symbols for architecture x86_64:
"_DGifCloseFile", referenced from:
OpenImageIO_v1_8::GIFInput::seek
OK problem was that osx does not permit static linking of external sources mainly into oiio.
Building dynamicaly works.
Running 2.3git
I guess for the release we'll have to copy some more .dylibs
Running 2.3git
OK i got something running here . Could someone plz point me to the buildphase where the binaries get patch with @rpath ?
I want to add OpenImageIO and OpenImageDenoiser too. fixing them afterwards with install_name_tool is horrible ... or i don't know what i'm doing.
At least not very perdictable thanks is advance.
In fact pyluxcore.so and BlendLuxCore seems to work on my other mac where no homebrew is installed. denoise is a bit of a problem. Can't get it to work sp far.
Do you need to set the rpath of pyluxcore.so (https://github.com/LuxCoreRender/LuxCor ... eLists.txt) ? Or luxcoreui executable (https://github.com/LuxCoreRender/LuxCor ... eLists.txt) ? Or ?
The binaries are directly from Intel (https://github.com/OpenImageDenoise/oidn/releases), it is strange, does the denoise command work ?
It works on the build machine but not the the other mac. But when i manually do
denoise does not find the lib not even on the build mac.
I found the if Apple section ... how might the iodn lib be namend ?? ahh OIDN_LIBRARY ... and ?? libOpenImageIO ? OIIO_LIBRARY ?
Sorry this is all the so new but i thing i got the symbols thing.
install_name_tool -change bal/bla/bla/libOpenImageDenoiser.0.dylib @rpath/libOpenImageDenoiser.0.dylib denoise
OK now i'm confused ... does pyluxcore need to be linked against OpenImageDenoise ??? I guess not since it works without
