Yes, I do.
You can see the screen in the first post.
Ok i see. You don't really need direct light sampling cache here. go uniform or log power. can we see your PGI all settings ( indirect light cache part) .
@Magog, can you post a test scene with just a single couch pillow (if the major problem with the denoiser is there) ? So I can check if there is some problem with Oidn and where it comes from (or is just a limit of the Intel software, at the end of the day all denoisers have some limit).
Dade wrote: ↑Fri Nov 29, 2019 11:12 am
If I set the render to 4k and after the calculation of the kernel, blender crash!
I also noticed that with the Particle System of the carpet and vegetation in the external area, the calculation does not start.
Magog wrote: ↑Fri Nov 29, 2019 12:21 pm
You may be running out of GPU memory, does it happens also if you try a CPU-only rendering (PATHCPU instead of PATHOCL) ?
Does it happen both with Oidn and BCD ?
Unfortunately, BCD denoiser requires a lot of RAM for each pixel so the total amount of ram used at high rendering resolutions is very high.
