Mediabook
- FarbigeWelt
- Contact:
Void Droplets Crowded, 2HD
Blender 2.81 beta, 5'700 objects, 1.11 M vertices
LuxCoreRender & BlendLuxCore 2.3 alpha0
openCL, path, CPU light tracing, Sobol, cache pgic caustics, 1'500 samples
intel core i7 4770K; 32 GB, DDR3, 1600 MHz; amd radeon rx 5700 xt, 8 GB, 2 cards; render time with export 1h33m
8.29 M pixels, 2.3 M samples/s, 1.58 GB VRAM Unbelievable, isn't it?
MacBook Air with M1
MacBook Air with M1
Re: Mediabook
Nice
Re: Mediabook
A green Xmas is coming
- FarbigeWelt
- Contact:
L.A.S.E.R.s scanning two transparent Artifacts
After the previews in Works in progress I can finally present the finished render.
2h10m31s, 5.76 MPixels, 4098 Samples, 3.0MSamples per s, 13.5 Rays per SampleLight and Word designing Creator - www.farbigewelt.ch - aka quantenkristall || #luxcorerender
MacBook Air with M1
MacBook Air with M1
- FarbigeWelt
- Contact:
Are there different Doors of Perception In Finite Mirrors?
0h47m58s, 5.76 MPixels, 4098 Samples, 8.2MSamples per s, 5.6 Rays per Sample
Path openCL with light tracing CPU0h47m58s, 5.76 MPixels, 4098 Samples, 8.2MSamples per s, 5.6 Rays per Sample
MacBook Air with M1
MacBook Air with M1
Re: Mediabook
The infinite mirrors look pretty cool. There seem to be some denoising artifacts (?) but they integrate so well with the image that they are not annoying, they are rather fitting.
- FarbigeWelt
- Contact:
Re: Mediabook
Thank you for the feedback!
Yes, there are some artifacts from the de-noiser. I had the same opinion about patterns fitting in or adding some enigmatic interpretations.
To remove de-noiser artifacts I had to increase to 65544 Samples, additionally I increased path depth for specular to 96, ideally depth is set to at least 168! And here some impression I gathered analyzing the renders.
MacBook Air with M1
MacBook Air with M1
- FarbigeWelt
- Contact:
Delicate Taste of Anonymous Seduction
Actually LuxCoreRender stands for "Physical based Rendering", well, it takes a while or even more to approach realistic looking imagery of empty glasses.
MacBook Air with M1
MacBook Air with M1
