Fox
Posts: 437 Joined: Sat Mar 31, 2018 11:17 am
Post
by Fox » Sat Nov 16, 2019 9:13 pm
I have problem with windows cmake-build-x64.bat
"C:\Users\Human\Documents\cp\WindowsCompile\Build_CMake\LuxCore\LuxRays.sln" (default target) (1) ->
"C:\Users\Human\Documents\cp\WindowsCompile\Build_CMake\LuxCore\samples\luxcorescenedemo\luxcorescenedemo.vcxpro
j.metaproj" (default target) (16) ->
j" (default target) (23) ->
(ClCompile target) ->
c:\users\human\documents\cp\luxcore\samples\luxcorescenedemo\luxcorescenedemo.cpp(220): error C2672: 'fill': n
o matching overloaded function found [C:\Users\Human\Documents\cp\WindowsCompile\Build_CMake\LuxCore\samples\lux
corescenedemo\luxcorescenedemo.vcxproj]
c:\users\human\documents\cp\luxcore\samples\luxcorescenedemo\luxcorescenedemo.cpp(220): error C2782: 'void std
::fill(_FwdIt,_FwdIt,const _Ty &)': template parameter '_FwdIt' is ambiguous [C:\Users\Human\Documents\cp\Window
sCompile\Build_CMake\LuxCore\samples\luxcorescenedemo\luxcorescenedemo.vcxproj]
c:\users\human\documents\cp\luxcore\samples\luxcorescenedemo\luxcorescenedemo.cpp(220): error C2784: 'void std
::fill(_FwdIt,_FwdIt,const _Ty &)': could not deduce template argument for '_FwdIt' from 'std::_Array_iterator<_
Ty,6>' [C:\Users\Human\Documents\cp\WindowsCompile\Build_CMake\LuxCore\samples\luxcorescenedemo\luxcorescenedemo
.vcxproj]
Posts: 810 Joined: Wed Jan 10, 2018 2:37 am
Post
by kintuX » Sat Nov 16, 2019 10:30 pm
confirming same
Build FAILED.
"C:\luxcorerender\WindowsCompile\Build_CMake\LuxCore\LuxRays.sln" (default target) (1) ->
"C:\luxcorerender\WindowsCompile\Build_CMake\LuxCore\samples\luxcorescenedemo\luxcorescenedemo.vcxproj.metaproj"
"C:\luxcorerender\WindowsCompile\Build_CMake\LuxCore\samples\luxcorescenedemo\luxcorescenedemo.vcxproj" (default
target) (21) ->
c:\luxcorerender\luxcore\samples\luxcorescenedemo\luxcorescenedemo.cpp(220): error C2672: 'fill': no matching
overloaded function found [C:\luxcorerender\WindowsCompile\Build_CMake\LuxCore\samples\luxcorescenedemo\luxcores
cenedemo.vcxproj]
c:\luxcorerender\luxcore\samples\luxcorescenedemo\luxcorescenedemo.cpp(220): error C2782: 'void std::fill(_Fwd
It,_FwdIt,const _Ty &)': template parameter '_FwdIt' is ambiguous [C:\luxcorerender\WindowsCompile\Build_CMake\L
c:\luxcorerender\luxcore\samples\luxcorescenedemo\luxcorescenedemo.cpp(220): error C2784: 'void std::fill(_Fwd
It,_FwdIt,const _Ty &)': could not deduce template argument for '_FwdIt' from 'std::_Array_iterator<_Ty,6>' [C:\
luxcorerender\WindowsCompile\Build_CMake\LuxCore\samples\luxcorescenedemo\luxcorescenedemo.vcxproj]
0 Warning(s)
3 Error(s)
Posts: 5672 Joined: Mon Dec 04, 2017 8:36 pm
Post
by Dade » Sat Nov 16, 2019 11:07 pm
I should have fixed the problem.
Fox
Post
by Fox » Sun Nov 17, 2019 1:04 am
Now i get different error:
c:\users\human\documents\cp\luxcore\samples\luxcorescenedemo\luxcorescenedemo.cpp(217): error C2065: 'LC_MESH_
MAX_DATA_COUNT': undeclared identifier [C:\Users\Human\Documents\cp\WindowsCompile\Build_CMake\LuxCore\samples\l
c:\users\human\documents\cp\luxcore\samples\luxcorescenedemo\luxcorescenedemo.cpp(217): error C2975: '_Size':
invalid template argument for 'std::array', expected compile-time constant expression [C:\Users\Human\Documents\
cp\WindowsCompile\Build_CMake\LuxCore\samples\luxcorescenedemo\luxcorescenedemo.vcxproj]
c:\users\human\documents\cp\luxcore\samples\luxcorescenedemo\luxcorescenedemo.cpp(223): error C2039: 'DefineMe
shExt': is not a member of 'luxcore::Scene' [C:\Users\Human\Documents\cp\WindowsCompile\Build_CMake\LuxCore\samp
Post
by Dade » Sun Nov 17, 2019 10:24 am
Fox wrote: ↑ Sun Nov 17, 2019 1:04 am
The build process is now working fine:
https://dev.azure.com/LuxCoreRender/Lux ... ildId=1011
It is like if you had and old version of luxcore.h around, "LC_MESH_MAX_DATA_COUNT" is clearly defined in it:
https://github.com/LuxCoreRender/LuxCor ... core.h#L64
Check your "c:\users\human\documents\cp\luxcore\include\luxcore\luxcore.h" file. Try to rebuild everything from scratch and check that "c:\users\human\documents\cp\luxcore" is updated (and unmodified) with Git.
Fox
Post
by Fox » Sun Nov 17, 2019 4:11 pm
The full clean build works. Thank you.
