Blender 2.8 objectid color
Fox
Post by Fox » Fri Nov 08, 2019 4:33 am
The objectid is broken in volume node, in material node it works, but random color generation by objectid does not work for volume absorption.
Both Blender ui and LuxCore ui. All objects render with same random color that is always red on all Blender material preview models too.
Egert_Kanep
Re: Blender 2.8 objectid color
Post by Egert_Kanep » Fri Nov 08, 2019 9:18 am
Has it worked before? Maybe it is a limitation of object id color
Post by Dade » Fri Nov 08, 2019 10:29 am
Object ID is used only for materials (i.e. surfaces), not volumes.
Internally, in LuxCore, volumes are a special kind of materials but the Object ID is just not used. The problem probably arise from there, the field may have been unintentionally exposed in Blender.
Fox
Post by Fox » Fri Nov 08, 2019 2:06 pm
I just copy pasted it from material node, it wasn't exposed. Would it be possible to add this feature?
Post by Dade » Fri Nov 08, 2019 3:16 pm
Yes, it should be, let me check.
Post by Dade » Sat Nov 09, 2019 2:51 pm
I checked the code and I was a bit confused because you are talking of object ID while I'm pretty sure you mean material ID.
Material ID is already fully supported for volumes and this is how it works:
- it is used if there is scattering event (i.e. an intersection) like the material ID of a surface is used if there is an intersection.
It is not used if the volume only absorb some path light but doesn't scatter the path.
Fox
Post by Fox » Sat Nov 09, 2019 3:51 pm
I have the object id color as a scale for textures.
Here is the sample file where 2 objects should have 2 different colors by random object id.
When you in material panel connect texture to transmission slot, it works like in below:
Blend file
id color sample.7z
(105.11 KiB) Downloaded 10 times
Fox
Post by Fox » Sun Nov 10, 2019 8:48 pm
When i use UV image texture in volume node, it writes error message "2d texture not supported"
UV map is scaled to 0, so it can only have 1 constant color value from single coordinate on image texture for entire object. In object node it works, but not in volume.
Post by Dade » Mon Nov 11, 2019 12:18 pm
A volume as no object associated so it is pointless to use Object ID texture: https://github.com/LuxCoreRender/LuxCor ... df.cpp#L98
The objectID field is always initialized with NULL_INDEX (i.e. 0xffffffff aka as white color) for a volume.
Fox
Post by Fox » Mon Nov 11, 2019 9:22 pm
Maybe then new 3d texture type "random constant color"
