Here is just an overview of what to do with LuxCore aov's. I call aov beauty image that is sum of the passes and combined pass is render beauty.
Caustics can be extracted with subtracting aov beauty from combined (render beauty). This intorduces negative values, but if extracted caustics now added to aov beauty, which has those bright fireflies, it evens them out and you get indentical result as combined. Makes sense, but this isn't a good thing I think. There seems to be some caustics, but majority of caustic contribution is missing from aov's
LuxCore multipass composite
- Egert_Kanep
Re: LuxCore multipass composite
There is a trick you can use if you want an image with only caustics: use PATHCPU and set balance between light paths and eye paths all in favor of light paths (i.e. 0.0).
You can use the same trick to get an eye paths only rendering by using a value of 1.0.
- Egert_Kanep
Okay, that's also good to know. My concern is that when I'm doing multipass compositing, I wan't to avoid ''hacks'' like subtracting and making negative values, because then my image breaks when I start tweaking individual aov's. Everything should be comped in additive.
There is a workaround, where I could keep separated caustics as individual image and then build a second node tree and add it as an extra pass. This would keep the additive workflow.
Thise fireflies appear in direct glossy aov.
I disabled light tracing and aov beauty and render beauty look different. This is bad news for me, I would expect them to be identical
You have lost me, I don't know how to map some of your term in my LuxCore nomenclature.Egert_Kanep wrote: ↑Mon Nov 04, 2019 11:07 pm I disabled light tracing and aov beauty and render beauty look different. This is bad news for me, I would expect them to be identical
Anyway, this is what I mean. This is a rendering with "0.0" (aka only caustics):
and this is a rendering of the same scene with "1.0" (aka everything-but-caustics):
if you sum the 2 images (note: sum, not blend/mix), the result is the complete rendering:
Isn't what you are looking for ?
- Egert_Kanep
I am trying to rebuild beauty using LuxCore aov's. but the result does not match with the result that is combined by render engine.
Ok, now I get it however, by composing all of them, you should get only this:Egert_Kanep wrote: ↑Tue Nov 05, 2019 10:26 am I am trying to rebuild beauty using LuxCore aov's. but the result does not match with the result that is combined by render engine.
The light tracing part is not included in any AOV.
So you should get the correct complete result if you sum:
- direct diffuse
- direct glossy
- indirect diffuse
- indirect glossy
- indirect specular
_and_
- light tracing output:
If you disable light tracing, your original procedure should work fine but caustics are likely to look bad because path tracing alone is really bad at rendering them.
- Egert_Kanep
Beauty combined from aov's has some much brighter pixels. I'mt trying to figure out why I cannot get identical result to beauty that is coming from render.
This is just opencl render without light tracing
- Egert_Kanep
Thanks B.Y.O.B for pointing out the clamping. This was the culprit behind my confusion. Clamping is not applied to aov's so I got those bright pixel, now everything makes sense
This may be considered a bug, is itEgert_Kanep wrote: ↑Tue Nov 05, 2019 12:55 pm Thanks B.Y.O.B for pointing out the clamping. This was the culprit behind my confusion. Clamping is not applied to aov's so I got those bright pixel, now everything makes sense
- Egert_Kanep
Well sort of. One would assume aov's to have same settings applied as beauty render
