I have a nvidia gpu i cant choose it .
Its either cpu or opencl which both use cpu.
Also does blender node work with luxrender ? It says not all node are supported will all nodes be supported in the future?
Where do i set up samples, it just render forever.
How do u use gpu render
Re: How do u use gpu render
Set the engine to path, device to OpenCl, then choose your GPUs in the performance panel.
If they don't show up, you will have to check your OpenCL installation, you could try to reinstall your GPU driver.
See the list here: https://github.com/LuxCoreRender/BlendL ... issues/272
In the render properties, "LuxCore Halt Conditions" panel.
