Procedural materials
Egert_Kanep
Post by Egert_Kanep » Wed Apr 18, 2018 9:28 pm
I started experimenting with procedural textures and first tried making a wood material.
Things I noticed: When using 3d mapping node, scale displays differently in preview and final render, maybe it only happens with blender textures, didn't check that yet. Scale differences was 100.
Ideas: It would be awesome, if we had a noise distortion node into which we could pipe other noises to have similar flow. In case of wood it would help to align small details to big wood texture. So basically ones has to create a texture and then pipe it into distort node and choose a warping method like wood, marble etc. Right now we already kind of have these things, but I cannot think of a way how to make another noise follow my wood texture flow.
Re: Procedural materials
Post by B.Y.O.B. » Wed Apr 18, 2018 9:34 pm
See https://github.com/LuxCoreRender/BlendLuxCore/issues/66
MichaelNer
Post by MichaelNer » Sat Jun 23, 2018 11:02 pm
Hi
Is it possible to render procedural tileable map sequence like cell or noise to files from softimage? I checked with rendermap option but it renders only one frame.
Egert_Kanep
Post by Egert_Kanep » Mon Jun 25, 2018 1:14 pm
Hi
Why would you want to render noise out of 3D software? Most of softwares out there all have similar or same noises built in.
Egert_Kanep
Post by Egert_Kanep » Fri Oct 11, 2019 8:41 pm
Some more procedural exploration. Next is going to be dust
Advanced pointiness, not the best way to display tough
Edge wear using the pointiness setup
Pointiness comparison
A better edgewear example
Post by B.Y.O.B. » Fri Oct 11, 2019 9:25 pm
Lovely pictures!
Racleborg
Post by Racleborg » Fri Oct 11, 2019 9:45 pm
Nice! :)
Post by FarbigeWelt » Sat Oct 12, 2019 12:32 am
Perfect! Very nicely done!
I did not know this worn off look is possible. I have to try this do in next time.
Windows 10 Pro 64 || 2x16 Cores, AMD Ryzen 3950X @3.5GHz, 64 GB RAM, DDR4 @3.2 GHz
2x openCL, AMD Radeon RX 5700 XT, 8 GB VRAM || Gfp = SFFT Gflops
arescet
Post by arescet » Sat Oct 12, 2019 5:26 pm
those are some awesome procedural effects!
do you mind showing your node setup? if it's no trouble of course :D
Egert_Kanep
Post by Egert_Kanep » Sat Oct 12, 2019 5:28 pm
Of course. I'm gonna upload once I organize them and add notes
