Thank you... There is a lot missing and far from perfect though... but I ran out of free time and nerves with this sceneFarbigeWelt wrote: ↑Thu Oct 03, 2019 1:36 pm I guess you are a good photographer and observer. Your computer generated images look very realistic. This perfection grows from all the details even in small things like the bowls of fruits, the meals card, the welding traces of the bar chairs, the porous edge of launch tables, the ocean's waves, the palm trees, et cetera.
There is nothing missing but humans enjoying the place.
Great work! Congratulations!
Hotel pool area concept design
Re: Hotel pool area concept design
Another good one!
I'm so happy to see such high quality work done in Luxcore. A dream become reallity. I think you should give it a spin on blenderartists.
Also can we have more infos: render time hardware résolution settings.
Btw do you speak french ? One of the card show a text in french. Ask because it is my native language.
Thanks,Sharlybg wrote: ↑Thu Oct 03, 2019 3:58 pm I'm so happy to see such high quality work done in Luxcore. A dream become reallity. I think you should give it a spin on blenderartists.
It was rtx2070+ryzen2700 on average it took 40 min. to render frame at 3000x2000 (makes me wonder now how much performance hit dispersion does, would it be faster without dispersion?)
I don't speak french and the menu should be in italian, unless I somehow managed to f*ck it up
Yes, not in term of samples/sec but in term of noise, dispersion add another dimension to sample (i.e. the wavelength).
The expression "A la Carte" is French but it is commonly used in Italy (the Italian translation is "Alla Carta"). The other (readable) voices are in Italian. No native Italian speaking will find odd to see the French expression in this context.
Yes the "a la carte" is pretty common in restaurants no matter what language is the menu. Just a fancy name for "menu" (Well I guess for french speaking person it's a normal name for menu )Dade wrote: ↑Thu Oct 03, 2019 5:51 pmYes, not in term of samples/sec but in term of noise, dispersion add another dimension to sample (i.e. the wavelength).
