Intel® Open Volume Kernel Library
Post by Dade » Tue Oct 01, 2019 9:25 am
Re: Intel® Open Volume Kernel Library
Post by Sharlybg » Tue Oct 01, 2019 11:38 am
Interesting: https://www.openvkl.org
Nice one ;)
Post by kintuX » Tue Oct 01, 2019 11:24 pm
Really fine... and I wonder is there any intention? Will there be time to give it some love? ;)
Post by Dade » Wed Oct 02, 2019 7:56 am
We already support OpenVDB file format but both OpenVDB and Intel library support only CPU rendering (i.e. lack the OpenCL support) so they are useless for use on that front.
Post by kintuX » Thu Oct 03, 2019 2:22 pm
From my experience, volumes are anyways too long, too hard to render on GPUs... so, just do hybrid for those too ;)
Post by Dade » Thu Oct 03, 2019 4:25 pm
It is a somewhat interesting idea because, at that point, I could use OpenVDB/OpenVolumeKernelLibrary CPU code (and only CPU ram to store the volume data, this would be a big plus).
However, it may work only for small, confined in space, objects (a fire, a cloud, etc.): the GPU will have to not render all paths affected by the volume so, for instance, if you use the volume for air scattering ... you would end with a CPU only rendering.
Post by kintuX » Thu Oct 03, 2019 4:44 pm
Which, for the time being & multi core CPUs nowadays wouldn't be such a problem,
while also being another huge benefit/advantage of LuxCore VS Corona ;)
