Yes, in my pool scene I keep running out of Vram with a lot of photons, so I'm hoping if they're sds only I can use high photon numbers and keep rendering using openCLDade wrote: ↑Mon Sep 30, 2019 9:14 am What do you mean ? Faster compared to ? The cache look up is done only for SDS paths so there are a lot less cache look up (I assume you mean this). However the cache creation time (and update) is exactly the same (a caustic is a caustic and I can not know if it will be seen trough a specular surface
PhotonGI caustic cache re-factoring
Re: PhotonGI caustic cache re-factoring
You are probably using too many photons: you can cut the amount of the photons and the updated period in half and obtain about the same result (using half of the ram) with a bit more overhead.lacilaci wrote: ↑Mon Sep 30, 2019 9:19 amYes, in my pool scene I keep running out of Vram with a lot of photons, so I'm hoping if they're sds only I can use high photon numbers and keep rendering using openCLDade wrote: ↑Mon Sep 30, 2019 9:14 am What do you mean ? Faster compared to ? The cache look up is done only for SDS paths so there are a lot less cache look up (I assume you mean this). However the cache creation time (and update) is exactly the same (a caustic is a caustic and I can not know if it will be seen trough a specular surface
hm, thanks for the tip, I forgot about update period settings...Dade wrote: ↑Mon Sep 30, 2019 9:25 amYou are probably using too many photons: you can cut the amount of the photons and the updated period in half and obtain about the same result (using half of the ram) with a bit more overhead.lacilaci wrote: ↑Mon Sep 30, 2019 9:19 amYes, in my pool scene I keep running out of Vram with a lot of photons, so I'm hoping if they're sds only I can use high photon numbers and keep rendering using openCLDade wrote: ↑Mon Sep 30, 2019 9:14 am What do you mean ? Faster compared to ? The cache look up is done only for SDS paths so there are a lot less cache look up (I assume you mean this). However the cache creation time (and update) is exactly the same (a caustic is a caustic and I can not know if it will be seen trough a specular surface
next up, hybrid glass?
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
Going to open a pool with some idea for v2.3, etc.
hm.. Something's not right here
useonlyforsds 0 useonlyforsds 1 volume setup material setup I'm not getting any light bounces within water
EDIT:
I get reflections back if I set light tracing glossiness threshold to 1 (I guess caustic cache uses same threshold value?)
volume still looks wrong
but rendering freezes at some point
EDIT:
There are two different properties for Caustic cache and Hybrid rendering at the moment. They must be set at the same value.
Actually even if you don't use any volume you will get very different lighting with sds only cache
useforsdsonly = 0 useforsdsonly = 1
Very different lighting compared to ? If the only difference is useforsdsonly = 0/1 and you are keeping hybrid rendering enabled: you are rendering the normal caustics 2 times in one case.
