Spheres scene challenge
Re: Spheres scene challenge
Post by epilectrolytics » Mon Sep 23, 2019 8:08 am
Thanks to @sarmath and @DEBIHOOD for fixing this scene!
I'm still mixing rough and dispersive glass for better reflections:
Martini
Post by Martini » Mon Sep 23, 2019 8:31 am
@DEBIHOOD
Congratulations, you've won a prize! :lol:
Here is 2 CFiu (2 binary CarbonFlux units :ugeek:) render
Time: 19:40:58.38 | 20,480 Samples | 599k Samples/Sec | 17.5 Rays/Sample | Bidir CPU + Metropolis
Composite
Composite
Raw render output
Raw render output
Post by B.Y.O.B. » Mon Sep 23, 2019 9:30 am
How did you get the incoming beam to show up?
I tried to fix that yesterday, but failed :?
Post by epilectrolytics » Mon Sep 23, 2019 9:59 am
I have no idea :oops:
I just took this file and modified it:
Luxcore spheres blend.7z
(604.43 KiB) Downloaded 116 times
I think darker tile colors help the beams to shine.
Last edited by epilectrolytics on Mon Sep 23, 2019 5:30 pm, edited 1 time in total.
Post by Dade » Mon Sep 23, 2019 10:42 am
It looks also a lot better in my opinion.
DEBIHOOD
Post by DEBIHOOD » Mon Sep 23, 2019 11:14 am
Thank you so much :D :D
It looks just fantastic inspiring :)
sarmath
Post by sarmath » Mon Sep 23, 2019 11:49 am
Yes dark themed from epilectrolytics looks cool :)
Windows 10 Pro Ryzen 9 3900x 2xGTX 1070ti 32 GB RAM
Post by epilectrolytics » Mon Sep 23, 2019 5:28 pm
When I switch (in my version of the file 4 posts above) to Hybrid I can reproduce the missing initial beam.
And also the caustic beams get way too bright (compared to BiDir) :?
No matter if CPU or OCL, with and without rough glass material component.
Post by Dade » Mon Sep 23, 2019 5:45 pm
It sounds like a wrong world volume setup :?:
Post by epilectrolytics » Mon Sep 23, 2019 7:11 pm
There is a fog box around the room, the camera and emitters are outside and no world volume defined.
When I define one and assign it as exterior to the fog box and the emitters, there is no change in rendering, still no incoming beam and the caustic beams are too bright.
(I think @FarbigeWelt has somewhere tested BiDir against Hybrid with lasers and volumes and found similar inconsistencies.)
