Spheres scene challenge
DEBIHOOD
Re: Spheres scene challenge
Post by DEBIHOOD »
Can someone please render with a lot of samples and full HD and denoiser?
That would be great, my pc is simply not capable of such torture :lol:
Martini
Post by Martini »
DEBIHOOD wrote: Sun Sep 22, 2019 11:47 am Can someone please render with a lot of samples and full HD and denoiser?
How many is "a lot" for this scene? I'm happy to let mine go overnight and/or all day tomorrow while I'm at work. I have an i9 9900K overclocked to 5GHz :twisted:
DEBIHOOD
Post by DEBIHOOD »
Martini wrote: Sun Sep 22, 2019 12:07 pm
I mean, that there would be no noise,
thank you in advance for being ready to spend your time :)
sarmath
Post by sarmath »
The longer the better ;) But overnight should be enough with your specs😁
Martini
Post by Martini »
sarmath wrote: Sun Sep 22, 2019 12:18 pm The longer the better ;) But overnight should be enough with your specs😁
Yes, I'll check it in 10 hours when I get up ;)
Just to make sure it's the correct one - do you want the one you posted, DEBIHOOD, or the one from sarmath with the extra-visible light beams?
Because as he points out, you can hardly see the beams in the one that you uploaded :cry:
DEBIHOOD
Post by DEBIHOOD »
Martini wrote: Sun Sep 22, 2019 12:33 pm Just to make sure it's the correct one - do you want the one you posted, DEBIHOOD, or the one from sarmath with the extra-visible light beams?
Use sarmath scene, visible rays look better and more close to the original scene
Martini
Post by Martini »
DEBIHOOD wrote: Sun Sep 22, 2019 12:45 pm Use sarmath scene, visible rays look better and more close to the original scene
Glad I checked :lol: restarting...
For what it's worth, attached is where your scene got to in just over 20 minutes (371 samples)
371 samples, denoised
DEBIHOOD
Post by DEBIHOOD »
Martini wrote: Sun Sep 22, 2019 12:53 pm For what it's worth, attached is where your scene got to in just over 20 minutes (371 samples)
On my cpu 265 samples in HD (720p) took 5 hours, oidn is also not supported
Martini
Post by Martini »
DEBIHOOD wrote: Sun Sep 22, 2019 1:32 pm On my cpu 265 samples in HD (720p) took 5 hours
:shock:
DEBIHOOD wrote: Sun Sep 22, 2019 1:32 pm oidn is also not supported
:o :( sorry to hear that!
Now, just over 1 hour has passed. Still quite noisy at 1K samples, but it might be starting to look OK after about 10K samples (1 CFu for all those who remember "CarbonFlux units"... ;) )
1,127 samples (denoised render view)
Martini
Post by Martini »
Well, here is the progress after 9 hours of rendering. It's up to just over 9,400 samples per pixel. I'll let it keep going all day while I'm at work as it's not quite noise-free yet (inside the glass spheres especially), although you have to look much closer to notice now... :D
Note that they have not gone through the compositor yet, because that only happens once rendering is complete. And if I stop it, well ... right now you can't resume a stopped rendering. Even to save the images I had to use the Snipping screenshot tool and then crop it with GIMP :geek:
9,360 samples (raw render view)
9,406 samples (denoised render view)
