DEBIHOOD
Post
by DEBIHOOD » Sun Sep 22, 2019 11:47 am
Can someone please render with a lot of samples and full HD and denoiser?
That would be great, my pc is simply not capable of such torture
Martini
Post
by Martini » Sun Sep 22, 2019 12:07 pm
DEBIHOOD wrote: ↑Sun Sep 22, 2019 11:47 am
How many is "a lot" for this scene? I'm happy to let mine go overnight and/or all day tomorrow while I'm at work. I have an i9 9900K overclocked to 5GHz
i9 9900K @ 5000MHz | 2x Gigabyte AORUS RTX 2080 Ti Extreme Waterforce WB 11G @ 2010MHz
Z390 Aorus Pro | 32GB Kingston HyperX Predator RGB @ 4300MHz
DEBIHOOD
Post
by DEBIHOOD » Sun Sep 22, 2019 12:12 pm
Martini wrote: ↑Sun Sep 22, 2019 12:07 pm
I mean, that there would be no noise,
thank you in advance for being ready to spend your time
sarmath
Post
by sarmath » Sun Sep 22, 2019 12:18 pm
The longer the better
But overnight should be enough with your specs
Windows 10 Pro i7 5820k 2xGTX 1070ti 16 GB RAM
Martini
Post
by Martini » Sun Sep 22, 2019 12:33 pm
sarmath wrote: ↑Sun Sep 22, 2019 12:18 pm
Yes, I'll check it in 10 hours when I get up
Just to make sure it's the correct one - do you want the one you posted, DEBIHOOD, or the one from sarmath with the extra-visible light beams?
Because as he points out, you can hardly see the beams in the one that you uploaded
DEBIHOOD
Post
by DEBIHOOD » Sun Sep 22, 2019 12:45 pm
Martini wrote: ↑Sun Sep 22, 2019 12:33 pm
Use sarmath scene, visible rays look better and more close to the original scene
Martini
Post
by Martini » Sun Sep 22, 2019 12:53 pm
DEBIHOOD wrote: ↑Sun Sep 22, 2019 12:45 pm
Glad I checked
restarting...
For what it's worth, attached is where your scene got to in just over 20 minutes (371 samples)
- 371 samples, denoised
DEBIHOOD
Post
by DEBIHOOD » Sun Sep 22, 2019 1:32 pm
Martini wrote: ↑Sun Sep 22, 2019 12:53 pm
On my cpu 265 samples in HD (720p) took 5 hours, oidn is also not supported
Martini
Post
by Martini » Sun Sep 22, 2019 2:02 pm
DEBIHOOD wrote: ↑Sun Sep 22, 2019 1:32 pm
sorry to hear that!
Now, just over 1 hour has passed. Still quite noisy at 1K samples, but it might be starting to look OK after about 10K samples (1 CFu for all those who remember "CarbonFlux units"...
- 1,111 samples (raw render view)
- 1,127 samples (denoised render view)
Martini
Post
by Martini » Sun Sep 22, 2019 10:02 pm
Well, here is the progress after 9 hours of rendering. It's up to just over 9,400 samples per pixel. I'll let it keep going all day while I'm at work as it's not quite noise-free yet (inside the glass spheres especially), although you have to look much closer to notice now...
Note that they have
not gone through the compositor yet, because that only happens once rendering is complete. And if I stop it, well ... right now you can't resume a stopped rendering. Even to save the images I had to use the Snipping screenshot tool and then crop it with GIMP
- 9,360 samples (raw render view)
- 9,406 samples (denoised render view)
