Room
wasd
Room
Post by wasd » Wed Sep 18, 2019 5:54 pm
Path OpenCL + Metropolis + PhotonGI, denoised
2k samples
CPU Bidir (sometimes GPU Path) + Metropolis | Log Power | Core i5-4570
Re: Room
Post by Sharlybg » Wed Sep 18, 2019 8:29 pm
Why metropolis with opencl ?
It is slower in GPU. Sobol is the way to go.
wasd
Re: Room
Post by wasd » Thu Sep 19, 2019 1:26 am
Sobol is ugly and should never be used. Also, I've heard there's way to do bidir with GPU and I think that's the right way to go.
As for speed, I just tried and it's basically the same for this one.
Re: Room
Post by Sharlybg » Thu Sep 19, 2019 9:35 am
UUHHH :shock: What ?
Your scene is simple. with large opening allowing sun to easily enter there is another windows in front. You also have simple shader no glass or volumetric involved. And metropolis is bad on GPU.
What do you mean ?
wasd
Re: Room
Post by wasd » Sat Sep 21, 2019 5:11 pm
Racleborg
Re: Room
Post by Racleborg » Sat Sep 21, 2019 8:01 pm
UUHHH :shock: What
I don't understand that either :o
Could you post a side-by-side comparison - or have you just done that? They look totally different?
Thanks
wasd
Re: Room
Post by wasd » Sat Sep 21, 2019 10:00 pm
UUHHH :shock: What
Thanks
Nope. I didn't intend to discuss this.
Here's comparison:
Path 3k samples
Sobol:
Metropolis:
Bidir+Metropolis 100 samples:
reflect.blend
(519.67 KiB) Downloaded 23 times
Re: Room
Post by epilectrolytics » Sun Sep 22, 2019 8:37 am
I like this one better than the first version which had too much direct light in the foreground for my taste.
But still this version is my favourite.
It seems like a simple thing but the reflections add layers of interesting complexity.
wasd
Re: Room
Post by wasd » Sun Sep 22, 2019 11:33 am
That wasn't scene though, just window test :) The room itself is empty.
I think this is the final version, there will be an animation.
Re: Room
Post by FarbigeWelt » Sun Sep 22, 2019 5:21 pm
Nicely done. Especially the bed and the windows. Did you try tone mapper Reinhard? Maybe you can make the room brighter while keeping look through open windows as is.
