Spheres scene challenge
sarmath
Post by sarmath » Thu Sep 19, 2019 10:55 am
Kudos to anyone who can setup this scene with LuxcoreRender.
This is the reference image rendered in old LuxRender.
And here you have link to the scene:
http://www.cg.tuwien.ac.at/~zsolnai/lux ... Spheres.7z
Scene contains textures and laser .ies file for the light.
Good luck.
Windows 10 Pro Ryzen 9 3900x 2xGTX 1070ti 32 GB RAM
Re: Spheres scene challenge
Post by Dade » Thu Sep 19, 2019 2:13 pm
LuxCore has true laser light source, use that.
typhoonofdvina
Post by typhoonofdvina » Fri Sep 20, 2019 8:52 am
Hello,
I had the same goal, struggled, but succeeded finally thanks to guidance by B.Y.O.B.
I'm attaching related stack exchange post instead just the scene itself, as I think, it is useful to know the pitfalls, I had to overcome.
The scene doesn't reconstruct exactly your image, but uses all those effect around volumetric caustics.
Hope that helps.
Btw, renders shown in that post are only drafts, but final result was really superb.
The post with scene: https://blender.stackexchange.com/quest ... i-backdrop.
Post by epilectrolytics » Fri Sep 20, 2019 6:02 pm
spheres_luxcore.blend.zip
(568.31 KiB) Downloaded 48 times
I don't get sharp prismatic rings :cry:
The original which is different from the reference in the opening point is a great piece of work, who made this?
I opened it on my MacBook where LuxRender is still installed but I forgot how the material system works there, especially volumes.
I had to use mix materials and eyeballing the IOR for the LuxCore version but it's way worse than the original.
And I'm not willing to run both versions on both computers all night long so here's only noisy examples, sorry.
DEBIHOOD
Post by DEBIHOOD » Sat Sep 21, 2019 12:01 pm
Ok that's what i have
a little later I will publish the file, because not everything is completed
When I use the area light source and turn on the “laser” checkmark in it, then the caustic becomes strange lines
sarmath
Post by sarmath » Sat Sep 21, 2019 3:04 pm
NIce results. I was playing with the scene as well and my result is also different than reference.
No mix materials. A bit of compositor adjustments for contrast/colour. Also added lightgroups to laser and floodlight for better control.
Bounces changed to 128 for light and eye like in original scene.
Large mutation probability to 25%
Max consecutive rejects 256
Rendered for about 6h
50% denoiser
And the scene file...
Spheres.zip
(2.68 MiB) Downloaded 37 times
DEBIHOOD
Post by DEBIHOOD » Sat Sep 21, 2019 4:50 pm
Less noisy render, I’ll post the scene tomorrow because I don’t have time right now.
Perhaps some caustics have disappeared due to a limited number of ray bounces
DEBIHOOD
Post by DEBIHOOD » Sun Sep 22, 2019 8:34 am
Here is the scene.
I also fixed problems with a limited number of bounces, now everything works fine.
Here is a file for a blender and for opening in luxcore standalone
Luxcore_spheres.7z
(1.91 MiB) Downloaded 57 times
sarmath
Post by sarmath » Sun Sep 22, 2019 11:34 am
Here is the scene.
Thanks DEBIHOOD you have been the closest to the reference but setting up scattering color to pure black you have almost lost that nice beams of light. I have changed it to dark grey to make it more visible. Also the result its achived with laser ies light like in original scene and not true laser as suggested by Dade. If someone can do it with true laser feel free to play with the scene. This is the result after correction...I am very satisfied :D
Luxcore spheres blend.zip
(3.01 MiB) Downloaded 47 times
DEBIHOOD
Post by DEBIHOOD » Sun Sep 22, 2019 11:41 am
I used a dark color for scatter because the same color was in the original scene, I don’t know why the dark scatter color is different in Lux and Luxcore
