Different Works in Progress
Material Null, Glass Homogeneous Test
Post by FarbigeWelt »
After I got currently stuck with orange juice in a glass I required a few new inputs since material Glass is still miraculous for me.
First, the easy test: What happens if one uses material Null as inter-mediator? (Please open the image to be able to read the texts.)
Material Glass, Matte, Null
There are openCL hybrid (large images) and CPU BiDir (small images) renders. Labeled yellow cuboids overlap (right) with both glass cuboids (top, bottom). Yellow cuboids overlap with cuboids made from material Null (top, bottom) the latter cuboids overlap each with one glass cuboid.
As you can see in openCL renders there is not much change in appearance of yellow cuboids glass intersection. In contrast CPU BiDir renders appear differently, i.e. yellow cuboid intersection with clear glass cuboid (top) appears as if made from glass if inter-mediator Null is used.
Let us keep in mind what is observable
(a) Looking top-down through Glass cuboid (ior crown glass)
- Null, top is saturated yellow
- Matte, top is dark almost black
- Glass, top is dark and
- Glass, top is dark yellow with yellow border because of inter-mediator Null
(b) Looking top-down through Glass (ior water)
- Null, top is saturated yellow with a black, horizontal bar in the middle
- Glass with inter-mediator Null, top is medium dark yellow (views into yellow cuboid) with thin yellow border (Null material)
(c) Looking from front side to bottom through Glass cuboid (ior crown glass)
- Glass, clear view into yellow cuboid and
- Glass with inter-mediator Null, very clear view into yellow cuboid, view is brighter than without inter-mediator
At least one question rises:
:?: Why are yellow cuboids' tops dark, see (a) and (b), especially with inter-mediator material Null too :?:
Paths: Glass top - Glass bottom - [Null] - Material m, i.e. SS[N]m | [] in some cases
m=Glass S, Matte D | S Specular, D Diffuse, N Null
How cautious did you look at the figures in the pictures? Did you notice the difference in convergence per sample for Sobol and Metropolis?
:P
MacBook Air with M1
Material Null, Glass Homogeneous Test - continued
Second, the complex test, this time with 'homogeneous' volume. (Please open the image to be able to read the texts.)
- no, no comments yet -
First, enjoy what you see!
Then, if you cannot resist, start scanning image for answers to glimpse-questions.
MacBook Air with M1
Disintegration
Clouds made from particles.
:D Just for fun. :D
Animated GIF, click-open image if it does not animate here.
MacBook Air with M1
lacilaci
Post by lacilaci »
FarbigeWelt wrote: Mon Aug 26, 2019 11:17 pm What is unbelievable here?
Object: cat-scaled.stl, Cat
Welp, tired a heavy scene at 24mpix resolution on nvidia and it just disables gpu on rendering. (like 15% usage and I only see lighttracing part of cpu). So maybe something is going on but performance drops so much that I'd rather render on cpu only at that point :/
Hey, Barkeeper! A Fire Shot, please.
Render result as is, i.e. no denoiser,no post processing.
Drink, Fire Shot
Drink, Fire Shot
Are you ready for imitation?
:lol:
MacBook Air with M1
My First Bright Orange whatsoever Drink
Orange Bright whatsoever Drink
:D :ugeek: :D
MacBook Air with M1
Intermediate Steps for Juice Simulation
Just a view impressions.
1
1
2
2
3
3
4
4
5
5
I required all these observations and more to conclude there is a way to simulate orange juice with current LuxCoreRender 2.2.
The object needs a setup meeting pulpy juice as close as possible. This means the simulated liquid needs to contain particles of different size, the smallest on top, the largest at the bottom. This is the key to image of former post.
MacBook Air with M1
Mr. Morf O'Kostix, Jr. - Undone Reflections
Undone Reflections
Please, click image to see animated gif pictures.
- -Sequel coming fall 2019 - -
MacBook Air with M1
M. Fodtau Obé Lizque's turn around
:D Because, it's possible :D + easy-peasy + :D lots o' fun. :D
Animated GIF image: M. Fodtau Obé Lizque
MacBook Air with M1
Liquidglass - (Why? Because I can.)
:ugeek: :mrgreen: :ugeek:
MacBook Air with M1
