Laci's wip
Re: Laci's wip
Post by B.Y.O.B. » Fri Sep 06, 2019 11:39 am
If you don't plan to scatter hundreds of palms, you could use group instances instead of hair particles and distribute them manually.
lacilaci
Re: Laci's wip
Post by lacilaci » Fri Sep 06, 2019 11:43 am
I don't scatter palms, they are placed manually. Hair was on the palm but it will always stay in it's original position even if I move linked object(palm) away.
Re: Laci's wip
Post by FarbigeWelt » Fri Sep 06, 2019 12:29 pm
Have you tried to make hair real? There is a way to make a mesh object from particles. Check the blender manual. Work woth a copy of the scene because it is a tricky way to go.
Do not forget to make mesh object using one user only (should be in the vertex menu, some button in the menu line, I mean the menu you can define e.g. vertex groups). If you do not make single user, you may get a real mess.
160.8 | 42.8 (10.7) Gfp | Windows 10 Pro, intel i7 4770K@3.5, 32 GB
2 AMD Radeon RX 5700 XT, 8 GB || Gfp = SFFT Gflops
lacilaci
Re: Laci's wip
Post by lacilaci » Fri Sep 06, 2019 12:39 pm
I know how to convert particles to object, however with hair this would result in completely insane poycounts (hair+children). For now I'm staying away from hair. Next time I'd either be fixed or I'll append objects.
lacilaci
Re: Laci's wip
Post by lacilaci » Fri Sep 06, 2019 1:05 pm
random preview of the day..
pool, glass, heavy tinted glass, unclamped sunlight no denoising no arch.glass
lacilaci
Re: Laci's wip
Post by lacilaci » Fri Sep 06, 2019 1:47 pm
Is it possible to get transparent alpha from glass shader? (not architectural)
Re: Laci's wip
Post by Dade » Fri Sep 06, 2019 2:06 pm
You can make any material transparent, it is a general material attribute and it is not related to glass (it is just the % of rays that will pass trough). For instance, you may want to use a 50% transparent mirror.
lacilaci
Re: Laci's wip
Post by lacilaci » Fri Sep 06, 2019 2:13 pm
I understand, but I want only alpha channel to have this transparency. So that I can compose background in post since I cannot use ocean mesh.
Re: Laci's wip
Post by Dade » Fri Sep 06, 2019 2:20 pm
Ok, I think you need to use OBJECT_ID_MASK AOV to get the mask of "glass" object, once you have the mask you can use photoshop/gimp/Blender for any type of compositing you may need :idea:
OBJECT_ID_MASK AOV isn't exactly the transparency but they are values between 0.0 and 1.0 so it can be scaled to any level of transparency you need (during post-processing/compositing).
lacilaci
Re: Laci's wip
Post by lacilaci » Fri Sep 06, 2019 2:26 pm
Oh I see :idea:
Thank you, I know what I have to do!
