Shadow Terminator problem
Post by Dade » Wed Aug 07, 2019 9:20 am
Introduction
This was the starting point in a quite extreme case:
Fixing a couple of problems
As first step I have fixed 2 problems:
1) the self-shadow problem in 2 triangles with a glancing angle with the light source (i.e. see the noise due to some self-intersection of shadow rays);
2) the horrible bounce back of light intensity on the edge.
and the result is:
Note: the black triangles on the edge are unavoidable, their geometric normal points away from the light source so there is no way to fix them aside increasing tessellation and/or using softer shadows (due to a larger light source, etc.).
"Taming the Shadow Terminator" ... when using bump/normal mapping
This is another test:
Now look what happen if I add bump mapping:
Lights magically appears from no where and start to illuminate also over the shadow termination. This is what
by Matt Jen-Yuan Chiang, Yining Karl Li and Brent Burley
https://www.yiningkarlli.com/projects/s ... nator.html
can fix. This is the same rendering using the shadow terminator avoidance factor described in the paper:
Better, now the renderings with and without bump mapping match each other.
P.S. this code is not part of beta3 but only available in daily builds.
lacilaci
Re: Shadow Terminator problem
Post by lacilaci » Wed Aug 07, 2019 9:46 am
Wow, never realized that the original shading was so insane! :D
Can't wait to test
EDIT:
Not being part of beta3 means I won't be able to use it in the build for 2.8 that Simon is preparing?
Post by B.Y.O.B. » Wed Aug 07, 2019 10:29 am
Hi, great work, this is definitely an improvement (although I still dream of a fix like in Thea render).
However, I have a scene here that shows some regressions.
Files attached.
I would include it if there were no regresssions.
New
New
Old
Old
smooth_shade_test.zip
(759.03 KiB) Downloaded 61 times
Post by FarbigeWelt » Wed Aug 07, 2019 11:30 am
Files attached.
What regressions do you mean? The ‚spheres‘ look better overall in the New than in the Old.
Post by FarbigeWelt » Wed Aug 07, 2019 11:34 am
Finally, I can finish the crescent moon I started over a half year ago. 8-)
Great work, Dade! And thank you for the nice introduction.
Post by B.Y.O.B. » Wed Aug 07, 2019 12:17 pm
Flip between the images and look at the right side. The ground plane (flat shaded) shows some very weird tiled shadowing artifacts with the new code.
lacilaci
Post by lacilaci » Wed Aug 07, 2019 2:35 pm
So aside some shading issues which B.Y.O.B reported already, this is really really cool.
Even hard sunlight is handled well without going into crazy polycounts!!!
Post by Dade » Wed Aug 07, 2019 2:37 pm
I should have fixed this problem:
Post by FarbigeWelt » Wed Aug 07, 2019 4:16 pm
This tops everything! That is perfect! Congratulations! 🍾
Post by Sharlybg » Wed Aug 07, 2019 6:37 pm
What a time to be alive. Thanks you so much ;)
