Very cool that you're contributing
The procedure is:
Create a fork of the BlendLuxCore repository on GitHub
Clone your fork to your local computer
Modify the files
Commit your changes
Push your commit to your fork repository
Create a pull request (request me to pull your changes into the main BlendLuxCore repository)
Then I'll review your pull request, maybe give you tips or ask to change something, and when everything is ok I will merge the pull request into the main BlendLuxCore repository
I hope this does not look intimidating, it's not too complicated. You can find help on all of these steps on github or the internet - or ask me if you're stuck somewhere.
Added the last 3 missing textures:
UV, Checkerboard 2D and Normalmap.
Note that the option to create an implicit normalmap already existed for the imagemap texture (because it's convenient), but this "free" normalmap node allows to use any color input as a normalmap, like the clouds texture in the example.
I doubt many users will need that flexibility, but it's nice to have.
The UV texture is mainly for testing your UV layout, seeing the tiling patterns better etc.
You're telling me that i'm no longer forced to create normal map outside of luxcore .Did never mind this possible. this is simply a great time saver thanks you clever man . Be sure i will abuse of this until i get drunk
No, you still have to use a normalmap as input to the normalmap node.
The normalmap texture in LuxCore just converts the colors (RGB) to an internal XYZ bump representation.
I guess we could write an image preprocessor that generates a normalmap from a diffuse texture before the rendering starts (like my normalmapgenerator does). Not sure if that's a good idea.
The lastest download for Linux from https://github.com/LuxCoreRender/BlendL ... opencl.zip seems to be missing the file /nodes/textures/blendernoise.py, /nodes/textures/checkerboard2d.py and /nodes/textures/normalmap.py
ImportError: No module named 'BlendLuxCore.nodes.textures.normalmap'
My github repo clone has them, so I suspect they got missed from the archive.
(... a bit later ...)
Doh! I just realised the problem is caused by my copying the /nodes/textures/__init__.py over from the git clone. Presumably that means the alpha4 download doesn't include them yet.
