In my case, denoiser version didn't match (.exe & .dlls inside bin folder) to that which is specified in the code (exporter). Comes from mixing versions. You can disregard the message or make a new, fresh & clean install.
kintuX wrote: ↑Tue Jul 23, 2019 2:39 pm
It is likely to be a mismatch between Oidn DLL and TBB DLL.
Aha, most likely it is. Cuz I rember, before OIDN was updated to the latest 0.9.0 I already used it, but had only overwriten exe & dlls. And since there were no issue rendering wise, i didn't pay much attention to it. Anyways, thanks for the tip! Nice to know.
Dade wrote: ↑Tue Jul 23, 2019 4:10 pm
kintuX wrote: ↑Tue Jul 23, 2019 6:44 pm
Fox wrote: ↑Wed Jul 24, 2019 10:35 am
But the TBB actually has more files than this 2 dll, it has around 120 files.
The full TBB is larger, but we use directly the Intel binaries for OIDN, and the distribution contains only the required TBB dlls + libs, total 4 files.
We need more stuff for Embree, however, and:
Dade wrote: ↑Wed Jul 24, 2019 9:41 am
Not sure if it has any implication here but there is always the potential problem of Embree and Oidn being compiled for 2 different TBB versions.
I also don't know how it could affect us. I'll try to investigate a bit deeper.
EDIT: BTW, an issue about this is already present in OIDN repo.
