strange corners of the room
DEBIHOOD
Post by DEBIHOOD »
as you can see in the corner of the room there is some kind of light, I have the feeling that this angle is shining and there you can see the sky, how to solve it?
This happens with almost all corners of the room.
I noticed that this happens with those corners where there is a window or doorway
What causes this problem?
Problems with shading?
(I deleted double vertices - nothing, normals rotated inside the room )
Re: strange corners of the room
It is likely to be a numerical precision problem. Just use solid walls, something like boxes, instead of planes.
DEBIHOOD
Post by DEBIHOOD »
Dade wrote: Fri Jun 14, 2019 6:44 pm It is likely to be a numerical precision problem. Just use solid walls, something like boxes, instead of planes.
this is not a plane, this is a cube (was :) ) with small rounding at the corners
Try adding a solidify modifier and enable the options "even thickness" and "high quality normals".
DEBIHOOD wrote: Fri Jun 14, 2019 6:55 pm this is not a plane, this is a cube (was :) ) with small rounding at the corners
You need thickness, the walls can not be just surface, they need to have some depth.
DEBIHOOD
Post by DEBIHOOD »
Thank you so much both of you again!
You saved my nerve cells :lol: :lol: :lol:
