problems with colored smoke
DEBIHOOD
Post by DEBIHOOD »
in viewport colors looks normal, but after rendering the colors look weird, why? How to solve this problem ? :?
Re: problems with colored smoke
You need a slightly more complicated node setup for colored smoke:
viewtopic.php?f=5&t=9&p=2918#p2918
Note that you usually want to drive the smoke color via absorption, not scattering, because it behaves a lot more predictable.
(you might have to play with the absorption depth depending on the size of your smoke sim to get a nice saturated color)
Here's also an example file:
viewtopic.php?f=2&t=737#p7633
DEBIHOOD
Post by DEBIHOOD »
Thank you very much, B.Y.O.B, for your very quick and clear answer :D
B.Y.O.B. wrote: Thu Jun 13, 2019 9:13 pm You need a slightly more complicated node setup for colored smoke:
Yes, I roughly understood that in luxcore as in cycles the choice of color for smoke is due to the absorption of color, I tried to do it but my domain became completely white, not just smoke, I did not know that you need to use the math node :o I just didn't understand how I needed to adjust the nodes to make the smoke look normal.
B.Y.O.B. wrote: Thu Jun 13, 2019 9:13 pm Here's also an example file:
Yes, I saw your video on YouTube with a smoke test, when I tried to make the smoke color, and I could not, I was puzzled for a few minutes and thought, "how did you make the smoke color and it looks normal???" :o :shock: :shock: :lol: :lol:
DEBIHOOD
Post by DEBIHOOD »
thank you so much again!
DEBIHOOD
Post by DEBIHOOD »
DEBIHOOD
Post by DEBIHOOD »
DEBIHOOD
Post by DEBIHOOD »
if you see a duplicate message, I tried to add a picture but for some reason went only a test, I apologize, and will try again to add the picture here
DEBIHOOD
Post by DEBIHOOD »
I couldn't add pictures, there's an error, okay, I'll stop trying.
