Swimming pool / Underwater / Caustics
Re: Swimming pool / Underwater / Caustics
Post by epilectrolytics » Tue May 07, 2019 3:04 pm
fabi wrote:
Mon May 06, 2019 9:23 pm
So when indirect and caustics caches are enabled, I understand that the caustics cache is computed with a number of visible objects which is inferior as it should be
Thanks for reporting this, maybe Dade can look into this and maybe fix it?
Caustic cache shouldn't get decreased when combined with indirect one.
Post by B.Y.O.B. » Fri May 10, 2019 6:48 pm
I replaced the tile texture so we can make this into an example scene.
Also added dispersion as a test, I like it (maybe make it a bit more subtle).
Not finished yet, have to tune the materials and lighting a bit (env. light is a bit too dark).
Just a denoised low sample render because my notebook has a weak CPU, tomorrow I get access to my main PC again.
Fox
Post by Fox » Sat May 11, 2019 3:18 pm
That scene looks very cool. Too bad the volumetric light is way too slow to render.
Selfie / Underwater / Caustics
Post by epilectrolytics » Sun May 12, 2019 1:21 pm
Good idea to add the sculpture!
"...and the selfie-cam of the new iphone
is now water-proof up to six feet under!"
:mrgreen:
Fox
Post by Fox » Sun May 12, 2019 11:13 pm
@ epilectrolytics
This must have been some serious render time :shock:
Post by epilectrolytics » Mon May 13, 2019 6:57 am
BiDir 1200 samples + OIDN = 3h on Ryzen 2700X
Also there is a procedural bump texture not helping with the speed, so yeah, not animation ready...
Fox
Post by Fox » Mon May 13, 2019 10:44 am
3h is awesome result, i thought it to be way way more.
Post by B.Y.O.B. » Mon May 13, 2019 2:32 pm
@epilectrolytics nice result, would also make a good example scene on its own!
Here's a longer render (around 1h 20min) with larger resolution on a more powerful computer, 1300 samples + denoising.
I tuned down the dispersion a bit (from 0.003 to 0.0015).
Fox
Post by Fox » Tue May 14, 2019 12:39 am
@ B.Y.O.B.
I like it.
Post by epilectrolytics » Tue May 14, 2019 7:59 am
Thanks, I'm still experimenting with materials and will report back when satisfied (will take some time because of a current animation render).
Good job with the pool scene!
