BlendLuxCore Development
Thread for talking about BlendLuxCore development.
Open issues: https://github.com/LuxCoreRender/BlendLuxCore/issues
Currently I discovered this bug and am waiting for confirmation.
Have to wait for a fix before I can continue the work on the material node editor.
Re: BlendLuxCore Development
Hi B.Y.O.B.!
I tried to install the new WIP exporter on windows and Blender 2.79 but when I try to activate it, I get an error.
I copied the needed DLLs into the bin directory of the addon.
However, when I restart blender and register it manually it works and I can use the engine (same code fails, if I execute it in the same Blender session after failed activation in user preferences).
Do you have clue, why the activation and registering fails? Is it an other code path?
File "C:\Program Files\Blender Foundation\Blender\2.79\scripts\modules\addon_utils.py", line 331, in enable
mod = __import__(module_name)
File "F:\Users\Michael\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\LuxCoreRenderEngine\__init__.py", line 8, in <module>
from . import engine, nodes, operators, properties, ui
File "F:\Users\Michael\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\LuxCoreRenderEngine\engine\__init__.py", line 3, in <module>
from ..bin import pyluxcore
ImportError: DLL load failed: Die angegebene Prozedur wurde nicht gefunden.
import os
os.chdir('F:\\Users\\Michael\\AppData\\Roaming\\Blender Foundation\\Blender\\2.79\\scripts\\addons\\LuxCoreRenderEngine')
import LuxCoreRenderEngine
LuxCoreRenderEngine.register()
I started to write this addon on Windows, everything worked back then.
Since the re-boot I only worked on it on Linux.
A few days ago I tried it on Windows and ran into errors just like you did, but I did not have the patience to fix it yet.
At least this means that all the needed DLLs are there, so we can rule out missing DLLs.
I thought it might be a Python version mismatch (latest Blender uses 3.6), we should check again which Python version LuxCore uses and what Blender 2.79 uses.
edit: What I found so far:
Interesting...
- Official Blender 2.79 uses Python 3.5.3
- The version in WindowsCompileDeps is 3.5.1: https://github.com/LuxCoreRender/Window ... evel.h#L26
- My LuxCore build on Linux seems to use Python 3.4, but I have no idea how to change that (and it's working)
- Latest Blender master uses Python 3.6, but on Linux my pyluxcore built with 3.4 works there, too.
Fixed two critical bugs: https://github.com/LuxCoreRender/BlendL ... projects/1 (see DONE section)
Does this mean that we can we can work with material without lose them when we import assets in new/other projects ?
In theory, yes, that's how the new Datablock ID properties work.
In practice, there's a bug that needs to get fixed first: https://developer.blender.org/T53509
by the way, at future BlendLuxCore developers: I created an overview of the project structure: https://github.com/LuxCoreRender/BlendL ... ructure.md
I hope it helps to quickly understand how the addon works.
If you have any questions or if you think something's not optimal, contact me.
You have a fresh new look on the code, while I am blind because I'm used to it.
Hi, I found a great article about automated testing using Travis CI for Blender addons: https://anzui.de/en/blog/2015-05-21/
I'd like to try that with BlendLuxCore. Travis CI needs permissions to access the LuxCoreRender organization's repositories.
I sent a request, it should come by mail.
I just see that you already approved it, thanks.
Implemented the basic structure for light export, still much to do.
https://www.youtube.com/watch?v=edd1YLG ... yucvtzBkN7
