LuxCore for Maya
motaman
Re: LuxCore for Maya
Post by motaman »
Acasta69 is the hero we need :!: :!: :!: :!: :!: :!:
instagram: motaman.art
motaman
Post by motaman »
Dade wrote: Tue Mar 12, 2019 5:28 pm BTW, interesting initiative: https://www.vfxplatform.com (from the linked AutoDesk thread).
It is! I just found out about it's existance :o :shock:
acasta69
Post by acasta69 »
Dade wrote: Tue Mar 12, 2019 5:29 pm
motaman wrote: Tue Mar 12, 2019 5:26 pm yeahh! you even have pymel , everything can be accessed using python in maya
So it sounds like it will a lot easier and faster to work with Python. Let's see if Acasta69 can help us :?:
Ok, I'll try in next days
motaman
Post by motaman »
acasta69 wrote: Tue Mar 12, 2019 6:01 pm
:o :shock: :o ok i will try too ! :D hello Acasta69
motaman
Post by motaman »
motaman wrote: Wed Mar 13, 2019 12:22 am i will be posting here.
https://github.com/motamano/MayaLuxCore
:) :geek:
Look like a fresh juice on a sunny day :D
acasta69
Post by acasta69 »
Here you can find binaries for Python 2.7:
https://www.dropbox.com/s/2dl2xobx926qx ... 27.7z?dl=0
Note that there is no pyluxcoretool.exe included.
Also note that numpy is required for pyluxcore to work.
I have tried to run the script that B.Y.O.B. linked here:
viewtopic.php?f=4&t=371&p=4098&hilit=Co ... put#p4116
Even if it gives an error at the end, overall it seems to work and produces correct output, so...
I hope these binaries work for you! :D
I report the error here as reference:
[LuxCore][5.554] Outputting film: pipeline_contour_lines.png type: 2
[LuxCore][5.741] Outputting film: IRRADIANCE.exr type: 23
[LuxCore][5.819] Outputting film: RAYCOUNT.exr type: 21
[LuxCore][5.866] Outputting film: RGB.exr type: 0
  File "pyluxcore_demo.py", line 154, in <module> main()
  File "pyluxcore_demo.py", line 141, in main
    session.GetFilm().GetOutputFloat(pyluxcore.FilmOutputType.IRRADIANCE, buffer, 0)
RuntimeError: Unsupported data type in Film.GetOutputFloat(): array
[LuxCore][6.022] [Intel(R) HD Graphics 530 Intersect] Memory used for OpenCL image pipeline: 17477Kbytes
This does not happen when run from python 3.5.
acasta69 wrote: Wed Mar 13, 2019 2:13 pm This does not happen when run from python 3.5.
The data type used by the python demo code has been introduced in Python v3.x, you just need to use another data type for v2.7 (https://github.com/LuxCoreRender/LuxCor ... mo.py#L210). pyluxcore.pyd should be fine.
acasta69
Post by acasta69 »
Dade wrote: Wed Mar 13, 2019 2:49 pm The data type used by the python demo code has been introduced in Python v3.x, you just need to use another data type for v2.7 (https://github.com/LuxCoreRender/LuxCor ... mo.py#L210). pyluxcore.pyd should be fine.
Thanks for explaining Dade :)
motaman
Post by motaman »
acasta69 wrote: Wed Mar 13, 2019 2:13 pm Here you can find binaries for Python 2.7:
I tried to run the script but i get
File "pyluxcoredemo.py", line 84
   print<"Blob [0]:",endl="")
SyntaxError: invalid syntax
:? I'm running python 2.7
