Pyluxcoretool exe not working on Windows
acasta69
Post by acasta69 » Mon Feb 11, 2019 9:01 am
Hi, I'm getting this error when running pyluxcoretool.exe from recent Windows builds:
Exception: [Errno 2] No such file or directory: 'C:\\support\\signature\\loader.py'
  File "pyscript", line 23, in bootstrap
FileNotFoundError: [Errno 2] No such file or directory: 'C:\\support\\signature\\loader.py'
AttributeError: module 'signature_loader' has no attribute 'pyside_type_init'
SystemError: could not initialize part 2
During handling of the above exception, another exception occurred:
  File "site-packages\PyInstaller\loader\rthooks\pyi_rth_pkgres.py", line 11, in <module>
  File "<frozen importlib._bootstrap>", line 968, in _find_and_load
  File "<frozen importlib._bootstrap>", line 957, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 673, in _load_unlocked
  File "c:\hostedtoolcache\windows\python\3.5.4\x64\lib\site-packages\PyInstaller\loader\pyimod03_importers.py", line 627, in exec_module
  File "site-packages\pkg_resources\__init__.py", line 33, in <module>
  File "platform.py", line 117, in <module>
  File "subprocess.py", line 50, in <module>
  File "signal.py", line 45, in <module>
  File "c:\hostedtoolcache\windows\python\3.5.4\x64\lib\functools.py", line 60, in update_wrapper
SystemError: <method-wrapper '__get__' of getset_descriptor object at 0x000000000012A900> returned a result with an error set
[5100] Failed to execute script pyi_rth_pkgres
I am not 100% sure if it's a local problem of mine: is there any Windows user that could please check if network rendering is working with the latest build?
Otherwise, it must be a problem either in PyInstaller or in the latest PySide2 version, 5.12.1 and I'll set automated builds to use the previous PySide2 version until I find a solution.
Re: Pyluxcoretool exe not working on Windows
Post by Dade » Mon Feb 11, 2019 10:21 am
Yup, I'm getting the same error from the latest build.
acasta69
Post by acasta69 » Mon Feb 11, 2019 10:40 am
Thanks Dade, for the time being I've modified the version in automated builds (5.12.0 was working fine).
acasta69
Post by acasta69 » Sun Mar 03, 2019 10:27 am
Hi, different problem on this executable: I've just noticed the following error when using pyluxcoretool.exe from latest 2.2alpha0 (both in standalone and BlendLuxCore):
C:\Users\xxx\Desktop\BlendLuxCore\bin>pyluxcoretool.exe
  File "C:\Users\xxx\AppData\Local\Temp\_MEI105402\pyluxcoretools.zip\pyluxcoretools\pyluxcoremenu\cmd.py", line 25, in <module>
ImportError: No module named 'PySide'
  File "pyluxcoretool.py", line 44, in <module>
  File "C:\Users\xxx\AppData\Local\Temp\_MEI105402\pyluxcoretools.zip\pyluxcoretools\pyluxcoremenu\cmd.py", line 30, in <module>
ImportError: No module named 'PySide2'
[13660] Failed to execute script pyluxcoretool
I think I've set up Windows builds so that they can use both PySide and PySide2, but here it seems that none of them has been found and packed by PyInstaller... :?:
Dade, B.Y.O.B., could you please check your PySide(2) install?
P.S. By the way, I'd like to help you with packing of Windows binaries if possible. I am not present as much as you, so I could be a bit late every now and then, but if you think this can be ok and of any help to you, just let me know. ;)
Post by Dade » Sun Mar 03, 2019 11:03 am
The pyluxcoretool.win.spec seems to look only for PySide2, not PySide1 and I have only PySide1 installed. I guess that is the source of the problem :idea:
Yes, sure, you are welcome ... to relief me from having to use Windows :mrgreen:
acasta69
Post by acasta69 » Sun Mar 03, 2019 11:19 am
I've overlooked that... :oops:
I'll try to fix it in the afternoon, but... you could upgrade to PySide2 on Windows, no?... :mrgreen:
Sometimes I think I begin to understand this :lol:
acasta69
Post by acasta69 » Sun Mar 03, 2019 4:36 pm
The pyluxcoretool.win.spec can now detect PySide or PySide2 install.
Apparently there's a new problem since some days: installation of PyInstaller in the Azure VM fails for some reason, so no pyluxcoretool.exe is generated in automated builds. I'm looking into this.
acasta69
Post by acasta69 » Sun Mar 03, 2019 5:36 pm
This should be fixed too, it was probably a bug in the pip version currently used in Azure.
Post by Dade » Sun Mar 03, 2019 9:31 pm
Good, thanks.
Fox
Post by Fox » Fri Mar 08, 2019 9:31 pm
The build i did today with "pip install pyside2==5.12.0 shiboken2==5.12.0"
there is no pyluxcoretool.exe
Maybe i need to go back to new pyside?
