LuxCore standalone questions
Fox
Post by Fox »
How can i change default film resolution, now it's 1920 x 1080 in LuxCore Ui?
I was able to add some presets, but default i can not find.
Made default font size 2x bigger, but to change default font type, if anybody can help with that?
Added longer refresh interval for this long CPU renders, but this is mostly pointless.
Also copied an color scheme from imgui forum topic.
Re: LuxCore standalone questions
To decouple resolution from window size I would recommend to open the Tool menu and select "Image view". This will also set the refresh time to 4 seconds.
Fox
Post by Fox »
B.Y.O.B. wrote: Sun Mar 03, 2019 8:11 am To decouple resolution from window size I would recommend to open the Tool menu and select "Image view". This will also set the refresh time to 4 seconds.
Yes i have it by default now in cfg
screen.tool.type = IMAGE_VIEW
Fox
Post by Fox »
If anybody likes to change their color scheme,
the stats window color is in luxcoreapp.cpp
ImVec4 LuxCoreApp::colLabel = ImVec4(
Most of it can be found in imgui.cpp
ImGuiStyle::ImGuiStyle()
Fox
Post by Fox »
About the fonts in LuxCore standalone, the tutorial was like below
// load the Roboto-Medium.ttf file from the media directory
ImFont *pRoboto26 = GUI->addFontFromFileTTF("D:/CP/Roboto-Medium.ttf", 26.0f);
GUI->compileFonts();
ImGui::PushFont(ImFont * pFont)
Now i'm not sure in what file i have to put this lines and where, imgui.cpp, imgui_draw.cpp, luxcoreapp.cpp
Post by lacilaci »
Fox wrote: Sun Mar 03, 2019 4:21 pm If anybody likes to change their color scheme,
Why isn't this a default?
It is kinda weird to see renderer UI have a color cast to it like it does now. It's almost like Dade is intentionally trying to throw people's color perception off, in a color sensitive work! :D
Fox
Post by Fox »
lacilaci wrote: Tue Mar 05, 2019 6:14 am Why isn't this a default?
It's more of a testing tool for devs, i'm all in with LuxCore blender internal when auto save feature comes, the new Blender 2.8 ui looks so beautiful.
Post by lacilaci »
Fox wrote: Tue Mar 05, 2019 7:55 am
Yeah I guess you're right... And yes 2.8 is great, I always build everything in 2.8 and then move to 2.79 for luxcore rendering(painfull process).
Fox
Post by Fox »
If somebody is in the need of doing Direct Light Sampling Cache or PhotonGi Cache in the standalone version,
then it's smart to set default render resolution, so you would not need to wait after 2 Cache builds.
luxcorerender\LuxCore\samples\luxcoreui\uiloop.cpp
Somewhere under the section
	// Create the window
Fox
Post by Fox »
HowTo get custom font and font size.
\luxcorerender\LuxCore\samples\luxcoreui\imgui_impl_glfw.cpp
Add what's in green, and make sure you set the correct url for the TTF font file on your drive.
