Cold Fusion
Re: Cold Fusion
Dade wrote: Mon Jan 29, 2018 1:01 pm P.S. going to check volumes absorption code, I have the strange feeling it may be something wrong.
Note that BlendLuxCore is implicitly creating a colordepth texture for the "Absorption" socket:
https://github.com/LuxCoreRender/BlendL ... __.py#L126
Maybe you mean that?
What I find weird in this scene is that the incoming laser beams are not visible. Or am I misinterpreting something?
Re: Cold Fusion
B.Y.O.B. wrote: Mon Jan 29, 2018 1:28 pm What I find weird in this scene is that the incoming laser beams are not visible. Or am I misinterpreting something?
Yes, that it is what I'm looking into.
Re: Cold Fusion
Had set the scale to match real world (1:1), Laser 1cm, volume definition as suggested by Dade... 2min later:
then fiddling some more cuz... oh, where are the lazers?
ahhh... there they are. :o
Maybe because they were set to 0 W & 0 efficiency ;)
Edit:
Q: Is it possible to implement Rectangle shape for Laser?
Re: Cold Fusion
Dade wrote: Mon Jan 29, 2018 1:45 pm
Ah, got it, the world has no volumes so all the rays starting from the camera travels into the void. The solution is to set the default world volume (or to set the prism and all other objects outside volume).
Re: Cold Fusion
kintuX wrote: Mon Jan 29, 2018 1:57 pm Q: Is it possible to implement Rectangle shape for Laser?
Well, yes but you can achieve the same result with a quad light source with the emission angle (i.e. theta) set to 0.
Re: Cold Fusion
Dade wrote: Mon Jan 29, 2018 2:13 pm Ah, got it, the world has no volumes so all the rays starting from the camera travels into the void. The solution is to set the default world volume (or to set the prism and all other objects outside volume).
I really need to add support for the default world volume.
Re: Cold Fusion
Dade wrote: Mon Jan 29, 2018 2:14 pm
Oh, sorry for my ignorance... is that a mesh light with emission shader & angles yet to be be exposed in blender or do i have to manually edit the scene file :oops:
Re: Cold Fusion
I still fear the first result can be achieve with laser :?
Re: Cold Fusion
kintuX wrote: Mon Jan 29, 2018 2:27 pm is that a mesh light with emission shader & angles yet to be be exposed in blender
It is already implemented, will be in the next release.
Re: Cold Fusion
typo error :
I still fear the first result can't be achieve with laser :?
