LuxCoreRender v2.1alpha2 released
Re: LuxCoreRender v2.1alpha2 released
Post by Dade » Wed Jul 04, 2018 9:42 am
kintuX wrote:
Mon Jul 02, 2018 8:54 pm
Using standard (old) strategies the catcher plane stays barely visible (1),
while using DLC strategy plane is fully invisible but strange splotching appears in shadow area (2).
I have never tried the combo shadow catcher and DLSC, I'm going to check what is going on.
Post by marcatore » Wed Jul 04, 2018 10:13 am
About the filtering of the lightcache samples, I mean something that can smooth the image area like the one you see over the table in this image.
http://forums.luxcorerender.org/downloa ... &mode=view
It seems that there are some "circle" with different brightness and I'm thinking to something that bring some samples with a distance rule and smooth together to smooth the transition from a "circle" to another one.
Is it something that had sense?
Post by B.Y.O.B. » Wed Jul 04, 2018 5:56 pm
As far as I understand it, the light cache only adjusts the probabilities of a light being sampled and is still unbiased.
The phenomenon in the linked image might be startup bias or something else caused by not enough samples (but it is a bit hard to tell without a ground truth image).
Post by Dade » Wed Jul 04, 2018 9:19 pm
Correct.
It is noise, a (huge) different level of noise. DLSC fallback to standard log power light strategy when a valid cache entry is not avilable for the point I'm rendering. It is very noticeable. Look, this is a scene with a well populated cache (1 sample per pixel):
and this is the same scene with not enough cache entries:
The surfaces without a valid cache entry are very easy to spot due the HUGE difference in noise. It is still unbiased so it will converge to the same result but in practice they look as artifacts.
Post by marcatore » Thu Jul 05, 2018 6:55 am
So probably it's not something like the Vray lightcache
https://docs.chaosgroup.com/display/VRA ... e+Settings
In that doc there is the "pre-filter" explanation
"Pre-filter – When enabled, the samples in the light cache are filtered before rendering. Note that this is different from the normal light cache filtering controlled by the Filter parameter, which happens during rendering. Prefiltering is performed by examining each sample in turn, and modifying it so that it represents the average of the given number of nearby samples. More prefilter samples mean a blurrier and less noisy light cache. Prefiltering is computed only once after a new light cache is computed or loaded from disk."
I know that Dade that you don't have the vray source code ( :) ) so my question is a bit useless but do you think it's completely another kind of algorithm?
Post by Dade » Thu Jul 05, 2018 7:21 am
It is different, V-ray sounds like a classic photon mapping where you can use the photon map to render direct light. Like B.Y.O.B. wrote, DLSC is only changing the probability to sample specific lights.
Post by kintuX » Thu Jul 05, 2018 11:38 am
After further tests i found it's a corner case. Happens only when both: Sun & World (HDRI, Sky or Flat Color) are used at the same time. Separately everything works as expected. & Those artifacts look like are from samples only on shadow's edges.
e.g.
EDIT1
Oh, i should have pay more attention - i assume it's related to:
Dade wrote:
Mon Jun 11, 2018 4:24 pm
Indeed, I have to handle hard shadow borders careful but I have an idea for that problem.
@ DLSC (aka LC pt.I)
TYVM for the great work and effort you put into.
Fox
Post by Fox » Tue Jul 31, 2018 5:28 pm
The v2.1alpha2 crashes with 2 hemi HDRi light maps, DLC on or off.
Post by B.Y.O.B. » Tue Jul 31, 2018 5:32 pm
Using two hemis with HDRI works here.
It would be good if you open a new thread in the user support section or a github issue and add the following:
- a small scene that shows the problem
- which OS are you using?
- Does it happen in final render or in viewport, or in both?
- which engine are you using (OpenCL or CPU)?
Fox
Post by Fox » Tue Jul 31, 2018 6:30 pm
I have recreated the scene and now i can't replicate the crash anymore.
Sorry B.Y.O.B
