LuxCoreRender v2.2 released
Post by Dade » Mon Sep 30, 2019 2:00 pm
Downloads:
Standalone and SDK: https://github.com/LuxCoreRender/LuxCor ... ender_v2.2
Blender v2.79b and v2.80 Addon: https://github.com/LuxCoreRender/BlendL ... xcore_v2.2
Changelog:
Available at https://wiki.luxcorerender.org/LuxCoreR ... Notes_v2.2
LuxCore major new features
  • PhotonGI indirect light cache
  • Integrated Intel Open Image Denoiser v1.0
  • New improved Random/Sobol sampler adaptive code
  • Front and back material transparency (aka light invisible object)
  • Added new textures: Power, Less Than, Greater Than, Dot Product, Position, Shading Normal, etc.
  • Shadow catcher is now easier to use with multiple light sources of any type
  • Added the support for new Disney BRDF material from Siggraph 2012 paper
  • Added Hybrid Back/Forward path tracing support
  • New Env. Visibility Map cache
  • Reworked Direct Light Sampling Cache
BlenderLuxCore major new features
  • Added support for all new LuxCore features described above
  • Ported the addon to Blender 2.8x
  • Started the Cycles scene reader project, basic Cycles node setups can now be read by BlendLuxCore (2.8x only)
  • Lots of small quality of life improvements: better tooltips, improved warnings/errors right in the UI, better defaults etc.
  • OIDN denoises the viewport once it pauses
  • Make volume socket export of material output more generic. This means users can now directly plug volumes into the interior/exterior volume sockets, without the need for a pointer node.
  • Made the error log more helpful (e.g. added a button that selects the problematic object for many warning types)
  • Implemented a workaround to have "delete and reconnect" functionality in the node editor
  • Most imagepipeline plugins are now automatically disabled in viewport when viewport denoising is enabled, to avoid artifacts
  • Intel integrated graphics OpenCL devices are now disabled by default because using them can lead to crashes
Note for Windows users: you have to install the Microsoft Visual C++ Redistributable for Visual Studio 2017.
Harvester
Re: LuxCoreRender v2.2 released
Post by Harvester » Mon Sep 30, 2019 3:25 pm
Thank you very much!
PetrT
Post by PetrT » Mon Sep 30, 2019 5:04 pm
Great news.Thank you very much
Post by Racleborg » Mon Sep 30, 2019 6:22 pm
Many many thanks. :)
zuljin3d
Post by zuljin3d » Mon Sep 30, 2019 7:09 pm
Great news! :o
Many thanks to all "LuxCoreRender" developers!
arescet
Post by arescet » Mon Sep 30, 2019 7:30 pm
LuxCore just keeps on keeping on and that is awesome! :D :D
Thanks to the wonderful developers!
chafouin
Post by chafouin » Tue Oct 01, 2019 2:09 am
Great work guys!
camara
Post by camara » Tue Oct 01, 2019 4:08 pm
Thanks! Amazing work!
BigGoga
Post by BigGoga » Thu Oct 03, 2019 9:38 am
Hi.
Only one processor works out of two.
Win 10 - 64bit Blender 2.8, 2.81, LuxCoreRender v2.2
Post by Dade » Thu Oct 03, 2019 10:03 am
Strange, it looks like the system is reporting only 18 cores available, have you tried to set by hand the number of CPU threads to 36 ? It is the setting on the right of your screenshot.
P.S. you should use tile rendering only if you run out of memory otherwise full image rendering is always better.
