LuxCore for Maya
motaman
Re: LuxCore for Maya
Post by motaman » Tue Mar 12, 2019 5:33 pm
Acasta69 is the hero we need :!: :!: :!: :!: :!: :!:
instagram: motaman.art
motaman
Post by motaman » Tue Mar 12, 2019 5:38 pm
Dade wrote:
Tue Mar 12, 2019 5:28 pm
BTW, interesting initiative: https://www.vfxplatform.com (from the linked AutoDesk thread).
It is! I just found out about it's existance :o :shock:
acasta69
Post by acasta69 » Tue Mar 12, 2019 6:01 pm
Dade wrote:
Tue Mar 12, 2019 5:29 pm
motaman wrote:
Tue Mar 12, 2019 5:26 pm
yeahh! you even have pymel , everything can be accessed using python in maya
So it sounds like it will a lot easier and faster to work with Python. Let's see if Acasta69 can help us :?:
Ok, I'll try in next days
Windows 10 64 bits, i7-4770 3.4 GHz, RAM 16 GB, GTX 970 4GB v382.05
motaman
Post by motaman » Tue Mar 12, 2019 6:11 pm
:o :shock: :o ok i will try too ! :D hello Acasta69
motaman
Post by motaman » Wed Mar 13, 2019 12:22 am
Post by Sharlybg » Wed Mar 13, 2019 8:30 am
i will be posting here.
https://github.com/motamano/MayaLuxCore
:) :geek:
Look like a fresh juice on a sunny day :D
acasta69
Post by acasta69 » Wed Mar 13, 2019 2:13 pm
Here you can find binaries for Python 2.7:
https://www.dropbox.com/s/2dl2xobx926qx ... 27.7z?dl=0
Note that there is no pyluxcoretool.exe included.
Also note that numpy is required for pyluxcore to work.
I have tried to run the script that B.Y.O.B. linked here:
viewtopic.php?f=4&t=371&p=4098&hilit=Co ... put#p4116
Even if it gives an error at the end, overall it seems to work and produces correct output, so...
I hope these binaries work for you! :D
I report the error here as reference:
[LuxCore][5.554] Outputting film: pipeline_contour_lines.png type: 2
[LuxCore][5.741] Outputting film: IRRADIANCE.exr type: 23
[LuxCore][5.819] Outputting film: RAYCOUNT.exr type: 21
[LuxCore][5.866] Outputting film: RGB.exr type: 0
  File "pyluxcore_demo.py", line 154, in <module> main()
  File "pyluxcore_demo.py", line 141, in main
    session.GetFilm().GetOutputFloat(pyluxcore.FilmOutputType.IRRADIANCE, buffer, 0)
RuntimeError: Unsupported data type in Film.GetOutputFloat(): array
[LuxCore][6.022] [Intel(R) HD Graphics 530 Intersect] Memory used for OpenCL image pipeline: 17477Kbytes
This does not happen when run from python 3.5.
Post by Dade » Wed Mar 13, 2019 2:49 pm
The data type used by the python demo code has been introduced in Python v3.x, you just need to use another data type for v2.7 (https://github.com/LuxCoreRender/LuxCor ... mo.py#L210). pyluxcore.pyd should be fine.
acasta69
Post by acasta69 » Wed Mar 13, 2019 3:28 pm
Thanks for explaining Dade :)
motaman
Post by motaman » Mon Mar 25, 2019 6:02 pm
I tried to run the script but i get
File "pyluxcoredemo.py", line 84
   print<"Blob [0]:",endl="")
SyntaxError: invalid syntax
:? I'm running python 2.7
