Quasirandom sampler
alpistinho
Quasirandom sampler
Post by alpistinho » Mon Mar 04, 2019 8:40 pm
Dade wrote:
Sat Feb 23, 2019 3:31 pm
kintuX wrote:
Sat Feb 23, 2019 2:51 pm
The Unreasonable Effectiveness of Quasirandom Sequences
"I present a new low discrepancy quasirandom sequence that offers substantial improvement over current state-of-the art sequences eg Sobol, Niederreiter,…"
http://extremelearning.com.au/unreasona ... sequences/
Uh, I looked and tried the code, it is incredible simple. It may be worth trying even if people where complaining of regular Sobol patterns ... I don't want even start to think what they will say about this.
I just gave it a shot and after quite a long time trying to understand the code I've got something running...
Why am I under the impression that something is not right :lol:
Re: CGI tech news box
Post by Dade » Mon Mar 04, 2019 10:54 pm
Have you tried to run the rendering for a very loooong time ? It may be just the samples correlation I was talking about. Plain Sobol, without shuffling looks similar.
alpistinho
Post by alpistinho » Tue Mar 05, 2019 12:34 am
I will try that, but I am not confident. I was expecting the patterns to be more like this: https://www.shadertoy.com/view/4dtBWH
Besides it does not look like to be converging to anything, so I guess I botched something. I will try to post some questions to better understand how the sampler interfaces with the rest of the code, because I am pretty sure I am missing some parts still
alpistinho
Post by alpistinho » Tue Mar 05, 2019 2:17 pm
As expected the result does not converge to the right output.
So, I was investigating and I have at least a couple of questions about the Sampler interface:
1. The GetSample method can return 3 different values based on how it is called. If the index is 0 or 1, the value returned is sample0 or sample1, that hold the value for the current pixel being rendered plus a small offset that I assume is to randomly sample the area of the current pixel.
If the index argument is any other value, the value returned depends on the Sampler type. Random returns an absolute random value and the Sobol returns the next value in the Sobol sequence based on the pass and index values in some way I don't understand.
What is this random value used for when the index value is not 0 or 1?
I see that this method is mainly called by the engines such as pathtracer. On this class the method is called with index 0 and 1 like that:
const float filmX = sampler->GetSample(0);
const float filmY = sampler->GetSample(1);
But it is also called like that:
camera->GenerateRay(sampleResult.filmX, sampleResult.filmY, &eyeRay, &volInfo,
sampler->GetSample(2), sampler->GetSample(3), sampler->GetSample(4));
const bool isLightVisible = DirectLightSampling(
		device, scene,
		eyeRay.time,
		sampler->GetSample(sampleOffset + 1),
		sampler->GetSample(sampleOffset + 2),
		sampler->GetSample(sampleOffset + 3),
		sampler->GetSample(sampleOffset + 4),
		sampler->GetSample(sampleOffset + 5),
		depthInfo,
		pathThroughput, bsdf, volInfo, &sampleResult);
And in this second case, all are covered by the default case on the switch.
Why do this calls the GetSampler with varying argument values if the result is always the same?
I've tried to implement this new sequence based on the Random and Sobol samplers, but substituting how the values are chosen. To debug I've substituted this new sequence for some rndGen->floatValue() calls in order to compare the results with what I get using the new sequence.
When I use rndGen->floatValue() to determine the sample0 and sample1 values I see no big difference in the rendering, but when I return a random value for the case where index != 0,1 the result looks correct.
I've put some prints and the value return appears to be in the correct range
Post by B.Y.O.B. » Tue Mar 05, 2019 2:47 pm
Do you have your changes in a fork online somewhere, so we can take a look?
alpistinho
Post by alpistinho » Tue Mar 05, 2019 2:51 pm
Sure, it's here: https://github.com/Alpistinho/LuxCore on the r2_sampler branch.
To use the sampler just put R2 in the configuration file.
Re: Quasirandom sampler
Post by Dade » Tue Mar 05, 2019 3:36 pm
You are not setting correctly the R2 sample dimension. R2Sampler::RequestSamples(const u_int size) tell you the sample dimensions (aka size) needed by the rendering engine and you are just ignoring the argument. Check the orginal code example at http://extremelearning.com.au/unreasona ... sequences/, where it uses "n=2", you have to use "n=size".
Each single sample produced by a sampler has a dimension and it is defined by the call to RequestSamples(). The sampler has a current sample, calling R2Sampler::GetSample(i) return the value of the "i" dimension, calling R2Sampler::NextSample() will move to the next one.
Samplers work exactly like in PBRT.
alpistinho
Post by alpistinho » Wed Mar 06, 2019 2:41 am
Thanks for the directions, I think I understand how it should work now.
It is still not working and it seems that the RequestSamples method is called at the beginning and not called again, so the samples are always the same. I will have a look at this tomorrow.
About something tangentially related on the SobolSequence code, how is that not a memory leak?
void SobolSequence::RequestSamples(const u_int size) {
	directions = new u_int[size * SOBOL_BITS];
	GenerateDirectionVectors(directions, size);
SobolSequence::~SobolSequence() {
	delete[] directions;
Is the RequestSamples only called once per object lifetime?
Post by Dade » Wed Mar 06, 2019 9:25 am
Yes, it is called once before starting to use samples to define their dimensions (why would you call it multiple times ?).
alpistinho
Post by alpistinho » Wed Mar 06, 2019 11:27 am
I had understood that it would be called every time the samples would be calculated and subsequent calls for GetSample would always return the same result until a new RequestSample was called.
I am reading the Sobol code to understand how it is done over there and it appears to me that what prevents the SobolSequence::GetSample from always returning the same value for the same index is the rngPass variable being modified between calls. Is that correct?
I had thought that the Sobol sequence would be followed sequentially for a longer time before changing the rngPass, but maybe that and the Cranley-Patterson rotation is what you were referring to by "shuffling".
