Re: BlendLuxCore Development
Posted: Tue Apr 28, 2020 4:41 pm
.blend?Odilkhan Yakubov wrote: ↑Tue Apr 28, 2020 4:26 pm Why the Denoised image is the same as Combined? Meaning not Denoising.
http://forums.luxcorerender.org/
Please make a report in the github issue tracker, describe how to reproduce the problem and show some images.Odilkhan Yakubov wrote: ↑Tue Apr 28, 2020 4:45 pm It shows on every project not on once. Denoising isnt worked for me or any setups need?
Report bug:B.Y.O.B. wrote: ↑Tue Apr 28, 2020 4:49 pmPlease make a report in the github issue tracker, describe how to reproduce the problem and show some images.Odilkhan Yakubov wrote: ↑Tue Apr 28, 2020 4:45 pm It shows on every project not on once. Denoising isnt worked for me or any setups need?
If it happens in every project it shouldn't be hard to provide a .blend file that reproduces the issue, right?
Thanks Dade for your answer.Dade wrote: ↑Tue Apr 28, 2020 9:56 am Adding a normalize flag it is pretty much trivial. The IES map is always transformed in an image map: https://github.com/LuxCoreRender/LuxCor ... s.cpp#L109
It is about adding here 3 lines of code to normalize the image map pixels: https://github.com/LuxCoreRender/LuxCor ... s.cpp#L131
Plus a line of code to parse the option (like the ".flipz" option). If someone want to take the task, it is really easy.
see https://github.com/LuxCoreRender/BlendL ... issues/272Odilkhan Yakubov wrote: ↑Sat May 16, 2020 11:54 am @B.Y.O.B. ,which nodes are not supported yet in Cycles Nodes reader tool?
As I remember Differance, Subtract and something like this converters are not supported yet, just black object if I guess.
