BlendLuxCore Development
johannes.wilde
Re: BlendLuxCore Development
Post by johannes.wilde » Thu Aug 08, 2019 12:13 pm
Thank you so much for LuxCore for Blender 2.8x!
I tested it today with this scene (Metropolis+OpenCl+PhotonGI+Environment Cache). Viewport renders smooth. I did the final render with a halt after 15 minutes on a 2080ti and i think the result after that short time is pretty good, for denoising does not help here with a lot of mostly uniform-colored structural textures. The only thing that did not work for me in this scene was HDRI lighting. Everything else worked for me and i did not run in to a single crash.
Cheers,
Johannes
Post by Sharlybg » Thu Aug 08, 2019 12:49 pm
Nice result ;)
Just wonder how fast sobol will be as it is better to use it on GPU than metropolis. Don't know but i think the render time can be lowered down considering you run it on a mighty RTX 2080 TI.
This card is like 2XRX Vega 56. With PGI+ENVcache it should be even faster.
johannes.wilde
Post by johannes.wilde » Thu Aug 08, 2019 1:07 pm
Thank you for that tip. I will try it later this day.
Racleborg
Post by Racleborg » Thu Aug 08, 2019 1:39 pm
Looks great. I particularly like the carpet!
Odilkhan Yakubov
Post by Odilkhan Yakubov » Thu Aug 08, 2019 3:27 pm
Dade wrote:
Thu Aug 08, 2019 12:10 pm
Odilkhan Yakubov wrote:
Thu Aug 08, 2019 5:20 am
Is it possible 2.8 with No Opencl version?
You can install Intel OpenCL CPU driver so you will be able to use the OpenCL version even without a GPU.
My Cpu is Core 2 Quad Q6600 2.6Ghz. Is it possible to use OpenCL with that CPU?
Allah bless us!
Post by Dade » Thu Aug 08, 2019 6:41 pm
May be, I don't know the exact requirements of Intel OpenCL.
alpistinho
Post by alpistinho » Thu Aug 08, 2019 6:49 pm
If he doesn't use any OpenCL engine and disable it in the imagepipeline, he should be able to use the OpenCL version, no?
lacilaci
Post by lacilaci » Thu Aug 08, 2019 7:06 pm
I have to say I like how the render settings are shaping up. Luxcore feels easier to use just by using few dropdown menus instead of 100 buttons.
Post by Dade » Thu Aug 08, 2019 9:04 pm
I'm afraid you get an error for the missing OpenCL-related DLLs as soon as you start the executable.
Asticles
Post by Asticles » Fri Aug 09, 2019 4:56 pm
hi all,
I'm testing the 280 build, and I see that viewport render does not update material emission changes.
Also, autosmooth values are ignored.
But great work!
Salvador Ureña
