Windows
Windows
Post by Dade » Thu Jan 24, 2019 11:45 am
@Acasta69: do you now if the VisulaStudio version we are currently using supports a more recent version than OpenMP 2.5 ?
I have a lot of code around looking like:
	#pragma omp parallel for
	for (
			// Visual C++ 2013 supports only OpenMP 2.5
#if _OPENMP >= 200805
			unsigned
#endif
			int i = 0; i < photons.size(); ++i) {
It was required to work with VisualStudio C++ 2013 but it is ugly. I would like to remove the #if.
alpistinho
Re: Windows
Post by alpistinho » Thu Jan 24, 2019 12:34 pm
Hey,
I did a quick search and found plenty of people asking about an update for OpenMP on VS, so I think the answer is no :( .
I've found however that it is possible to use Clang with VS, so maybe that's an option.
https://marketplace.visualstudio.com/it ... -toolchain
acasta69
Re: Windows
Post by acasta69 » Thu Jan 24, 2019 12:49 pm
Hey,
I confirm, I was looking at the same topic this morning and it is still 2.5.
About clang on Windows, that's' something I'd like to try, but probably not so soon due to lack of time...
Windows 10 64 bits, i7-4770 3.4 GHz, RAM 16 GB, GTX 970 4GB v382.05
Re: Windows
Post by B.Y.O.B. » Thu Jan 24, 2019 1:03 pm
What about a typedef like I did in the imagepipeline plugin tutorial?
	typedef unsigned int itertype;
#else
	typedef int itertype;
#endif
for (itertype i = 0; i < pixelCount; ++i) {
Re: Windows
Post by Dade » Thu Jan 24, 2019 2:09 pm
Fine for me.
