Page 28 of 109
Re: PhotonGI cache
Posted: Mon Feb 11, 2019 2:58 pm
by marcatore
Dade wrote: Mon Feb 11, 2019 2:37 pm A new code using regular visibility points:
The light intensity is a lot more uniform and smooth, thanks to the uniform distribution the cache look up is also 2 times faster (check the samples/sec) and independent from number of photon traced or look up radius. The pre-processing is also a lot faster.
P.S. this starts to looks exactly like a V-Ray output...
yes...it's really really similar to Vray Lightcache!!!
Good job.
Re: PhotonGI cache
Posted: Mon Feb 11, 2019 3:27 pm
Historical moment ! Very nice Dade ;)
Re: PhotonGI cache
Posted: Mon Feb 11, 2019 8:19 pm
Yes same as Vray 3.6.
Luxcore
Vray
Re: PhotonGI cache
Posted: Mon Feb 11, 2019 10:46 pm
This thing work really well ... I mean R E A L L Y:
- reduces the number of parameters;
- reduced the amount of ram used (it is pretty much constant and not based on the number of photons you trace !);
- makes the pre-processing a LOT faster;
- makes the rendering a LOT faster;
This is a a debug view of indirect cache:
and this is a 60 seconds rendering:
Add the denoiser and it is done. Not only it is fast but the quality of light is so good.
I have pushed this patch. It affects only the indirect cache, I will now check if I can use a similar solution for the caustic cache. A lot of parameters have been removed/changed so I'm not sure if it can work well with the not yet updated BlendLuxCore.
P.S. this thing on GPUs...
Re: PhotonGI cache
Posted: Mon Feb 11, 2019 11:30 pm
Awesome!
By the way, do you know why those two wall panels are black in the cache? I noticed something similar in a testscene as well, some surface just being black even when using a matte material and after checking for double vertices and twisted normals.
Re: PhotonGI cache
Posted: Mon Feb 11, 2019 11:58 pm
by alpistinho
B.Y.O.B. wrote: Mon Feb 11, 2019 11:30 pm Awesome!
Looking closely around that panels the two curved things around them are different between the two sides. The one in the right seems to have been included in the cache, while the one in the left does not.
Re: PhotonGI cache
Posted: Tue Feb 12, 2019 12:07 am
I have updated the Blender addon with the latest property changes.
Re: PhotonGI cache
Posted: Tue Feb 12, 2019 4:53 am
Are all shaders supported now?
Re: PhotonGI cache
Posted: Tue Feb 12, 2019 5:47 am
Oh, this is really fast now. Default numbers I think are a bit low.
But I still get weake light in GI (using same depth for photons as for GI)
cache
no cache
Re: PhotonGI cache
Posted: Tue Feb 12, 2019 6:03 am
also, sometimes high power samples are still showing through
more cache, larger lookup, clamping, nothing helps!
Edit: Actually if I make lookup really big(40cm) then it's ok
But it takes some trial and error figuring out proper value for scene...
Rendering is so fast now that it can be easily used for some hardcore viz even on cpu, on gpu we'll have like 1 minute renders :D
