LuxCoreRender - Nodes
stanland
Post by stanland » Mon Sep 17, 2018 5:53 am
I don't know what is the Luxcore nodes technical limitations but Is it possible for example to do something similar to Node Wrangler http://gregzaal.github.io/node-wrangler/ or Cycles Frame Node https://docs.blender.org/manual/nb/dev/ ... frame.html
Re: LuxCoreRender - Nodes
Post by B.Y.O.B. » Mon Sep 17, 2018 7:55 am
Frames work just like in Cycles: select a few nodes and press Ctrl+J.
I have also thought about implementing some node wrangler features in our node editor.
Which features do you need the most?
stanland
Post by stanland » Mon Sep 17, 2018 9:34 am
This is awesome that this feature exist in Luxcore but at the same time embarrassing how did i missed that shortcut option! :oops:
Top 2 features from Node Wrangler in my opinion!
1) (Ctrl+Shift+Lmb) Once you try to connect using this shortcut you never want drag nudels manually anymore.
2) (Alt+Rmb) This makes mixing very easy and fast.
stanland
Post by stanland » Mon Sep 17, 2018 10:03 am
Is it possible to make a node groups like in cycles?
https://docs.blender.org/manual/en/dev/ ... roups.html
Post by B.Y.O.B. » Mon Sep 17, 2018 12:47 pm
Not yet, it is on the to do list: https://github.com/LuxCoreRender/BlendL ... issues/127
