Page 16 of 18
Re: Mac OS
Posted: Wed Nov 07, 2018 10:49 am
mick wrote:
Wed Nov 07, 2018 10:21 am
They are available when adding a new material in the node editor, but not in the material panel.
This is the intended behaviour.
It would be a lot more work to have two material editors.
Re: Mac OS
Posted: Wed Nov 07, 2018 7:28 pm
by robbrown
Are you using the scene files in the main repo LuxCore repo or the LuxCoreTestScenes?
Can you send me a crash log?
Should be in:
  1. * Applications->Utilities->Console
    * Left Pane -> User Reports -> luxcoreui_*.crash
    * Right click on the crash log to reveal location in finder
Re: Mac OS
Posted: Thu Nov 08, 2018 9:11 am
by epilectrolytics
mick wrote:
Wed Nov 07, 2018 10:13 am
Also the non-openCL version crashes with the sample files.
On my MacBook I can't open the test scenes with non-openCl luxcoreUI:
RenderConfig loading error:
Unknown render engine type in RenderEngine::ToProperties(): PATHOCL
When I open the blend files in Blender with blendluxcore non-openCl (CPU-PATH) they crash when trying to render.
Re: Mac OS
Posted: Thu Nov 08, 2018 9:17 am
You can change the render engine in the render.cfg file: https://github.com/LuxCoreRender/LuxCor ... er.cfg#L16
The available engine types are listed here: https://wiki.luxcorerender.org/LuxCore_ ... der_Engine ("PATHCPU", "TILEPATHCPU" etc.)
Re: Mac OS
Posted: Fri Nov 09, 2018 11:50 am
by epilectrolytics
Thanks B.Y.O.B.
Changing from "PATHOCL" to "PATHCPU" in the render cfg results in just another "Unterminated quote in property: renderengine.type" error.
There was hoping to initiate a LuxCoreUI crash so I could help @robbrown with the crashlog.
(Currently trying to build a Windows PC so I can finally render stuff in Cycles, LuxCore etc but apparently Blender won't work with an RTX 2070 so I'm stuck there too...)
Re: Mac OS
Posted: Fri Nov 09, 2018 12:21 pm
Can you show the relevant part of the file?
Maybe you used the wrong quote character?
You have to look for a build with latest CUDA kernels, I think there are a few floating around. E.g. look on blenderartists.
Re: Mac OS
Posted: Fri Nov 09, 2018 8:48 pm
by epilectrolytics
Success!!!
Deleted the food scene, downloaded again, changed "PATHOCL" to "PATHCPU" and suddenly all those delicious things appear on my screen!
Works with both standalone versions (openCL and non-openCL).
Also works with "PATHOCL" and 'opencl.cpu.use = 1' + 'opencl.gpu.use = 0'.
The original file takes forever to compile kernels, I stopped the process after 45min.
Dunno what went wrong on the earlier attempt.
We'll see if I'm up to the task of dealing with blender builds, I never had a PC or worked with Windows, all new stuff to me :oops:
At least Black Friday and Christmas are approaching :)
Re: Mac OS
Posted: Fri Nov 09, 2018 9:08 pm
by mick
After editing the .cfg of the food sample, rendering proceedes until 61% and the crashes with
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
abort() called
Logical CPU: 0
Error Code: 0x02000148
Trap Number: 133
My own simpler scenes can be rendered successfully.
Re: Mac OS
Posted: Fri Nov 16, 2018 7:46 am
by robbrown
I was able to complete the fruit scene with non-opencl alpha release on my macbook pro (not the machine I build on) with the instructions about .cfg changes a few posts up. Can you describe what you have going on for your scene setup or just attach the .cfg file and crash report? Should be able to grab the old report as Mac saves them in the console utility.
I've entertained the idea of writing metal support since OS X OpenCL tends to have its glitches and oddities like kernel builds are slow as epilectrolytics noted.
Re: Mac OS
Posted: Fri Nov 16, 2018 9:15 am
It would like a lot of work, try to check if there is something like a OpenCL-over-Metal emulator (like the OpenCL-over-Vulkan project I'm looking at as an option for using NVIDIA RTX acceleration).
